Question about GoVideo DV1130 DVD Player/VCR
Unit has not been used in over year, just plugged in and am unable to open the DVD door... the VCR portion workds fine....
    Guru:
  • 125 Answers
My guess would be the gum ring that moves the tray in and out. It is either fallen out of the pully, deformed or cut. If damaged it has to be replaced.
BR
Bruce
Posted on Sep 08, 2010
  • Bru Sha Sep 08, 2010
    By gum ring i meant rubber belt!
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
DVD Player won't open
check if your dvd door is driving by belt or gear . if its belt ,check if its slack, if gear check for worn gear. weather gear or belt check if the motor driving it responds each time you press the eject button .check if the eject switch is ok .then if all this are ok ,check the ic controlling the eject/close functions
Jul 11, 2008 | Samsung DVD-V1000 DVD Player/VCR
DVD will not eject from JVC HR-XVC27U
Disconnect the Power Cord. Open the Case and go to the DVD unit. On the right side of the unit you will see an indentation which is the mechanical portion of the DVD Unit.
Push the indentatation in, it is the eject switch. The DVD unit door opens remove the DVD stuck in the unit.
Put cover back on plug the unit in, insert a workable DVD and all should be OK.
The problem was the unit could not read a Defective DVD which I made and the unit was locked in to reading the DVD.
I hope this helps
May 22, 2008 | JVC HR-XVC27U DVD Player/VCR
Dvd player
you must eject the tape in order for the disc player to work
Mar 30, 2008 | Sanyo DVW-7200 DVD/VCR
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd drawer will not open
seems like the rubber band is broken. no there is not secret back door to it..you have to open it and change the rubber band. it is not that complicated
Mar 26, 2007 | Philips DVD750VR DVD Player/VCR
GoVideo DV1130 DVD Player/VCR Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
