Question about Amana ABC2037DTS Stainless Steel Bottom Freezer Refrigerator
The motor on my amana abc2037dts refrigerator continually runs even though the both the freezer and refrigerator sections are at the proper temperature. I'm afraid the motor will burn out. I have dusted the coils as much as possible but they're very hard to reach. is there anything i can do?
  • Amana Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 11, 2011 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer, model abc2037dts, there is a motor noise that goes on for 8 seconds then shuts off, then a few clunks for 2 seconds
Even if you do not have the water hooked up for the dispenser and ice maker, the fridge still makes the sound as if it is filling up the ice maker. If you lift the metal arm beside the ice maker, the sound stops happening because it thinks that the ice bucket is full.
Aug 08, 2010 | Refrigerators
Amana ABC2037DTS Stainless Steel Bottom Freezer Refrigerator The refrigerator is no longer cooling; the freezer works though.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 18, 2010 | Amana ABC2037DTS Stainless Steel Bottom...
Fridge section not cooling properly
your evaporator iced up, defrost it, leave it off for 24 hours.Check defrost heater,timer, and the fan motor.
Apr 07, 2010 | Amana ABB1927DE Bottom Freezer...
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
My amana freezer on the bottom has stopped making ice and the freezer isn't freezing properly even though i have it set to 7 which is the highest setting
check to see if there is frost build up on back wall .if it does u have defrost problem could be comblicated issue not knowing your expertise need make and model
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Regrigerator isn't cooling - freezer is fine....
Make sure there is not a ice build up in the back wall of the freezer.
If so, you have a defrost issue.
Make sure the freezer fan is blowing.
If so, you have a thermistor issue.
Feb 22, 2009 | Amana ABC2037DTS Stainless Steel Bottom...
Ice Dispenser Problem - Runs for no reason
I think your problem is in the dispenser lever switch or the lever itself. Don't worry about the upper door switch, it's the dispenser switch that's sending power to the auger motor. I would give you a part number but the posted model number is for a bottom freezer model. Catriver..
Dec 06, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Amana ABC2037DTS Stainless Steel Bottom Freezer Refrigerator Logo
48 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
