I have a 37inch tv and want to know if it is possible to wire up my Logitech x 540 surround sound system through the tv . If so what cables do I need and how do I do it ?
Thanks
HERE is a link to the Z-540 manual. It should help. Connect the green plug from the audio input cable to the "line out" jack on your TV. Do NOT use the black or orange plugs. WIth a 2 channel card like your TV's you will not get sound from the rear speakers unless you enable matrix mode through the remote.
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
Hey it worked great but the front right speaker is not working all the other speakers are fine but there is no sound coming out of that one
It should be a aduio output.. then a red and white thing should be avalabile ....
My TV is LG 37inch LCD TV 2 x HDMI HD Ready 1366 x 768 5000:1 - 37LC55
Yes the logitech box does look like the picture
It would appear I have the model wrong its an LG 37LC2D - I'm not sure what a line out jack is . All I have at the back are :
Inputs: AV In 1 RF In Y AV In 1 S-Video In 1 Scart Jacks 3 Component in + Audio 1 Digital Audio Out 1 Variable Audio Out 1 HDMI/HDCP Input 1 RGB In 1
Which jack point am I supposed to put the green lead into .
And do I just use the leads from the actual system - not any new ones !!
hey i'm connected the green cable to my proview 32 inch tv and it works except for the frnt right speaker (RED) all the other speakers work fine..whats the problem?
I want to plug my X540 to my DIVX player Sunny SNY4005. My TV is SAMSUNG LE32A451C1. Can u pls assist me to plug? Thanks
what lead do i need for a tecnika tv
i have the same problem i dont know how to connect the logitech x540 to my hdtv my hdtv is magnavox 32 inch here how it looks likehttp://electronics.hsn.com/magnavox-32-l...
how am i ganna get this surround to work with this tv and my ps3
thank you for ur help
can i connect my logitech x-540 speaker system to my tv? if so what cables do i need
i need help, i havent got any audio input cables of whatever i need. im really confused how to connect my x-540's to my plasma
This should be posible yes. BUT
First, confirm that the logitech box looks like this:
http://techgage.com/reviews/logitech/x-5...
Can you let us know which TV you use? Make and model.
Then I can tell you what cables you need.
Jens
www.sumox.com
