Question about Magellan Maestro 4040 GPS Receiver
My Magellan Maestro 4370 GPS freezes on boot-up with the Magellan logo and spinning dial. Do you know if this just needs a software upgrade or whether it has other problems? Thank you.
  • 4 Answers
SOURCE: Magellan GPS
Online at Magellan website you can update your magellan maestro 3100
Posted on Mar 29, 2008
  • 373 Answers
SOURCE: International Maps for Magellan Maestro 4250 GPS
If I am correct you can put it on the sd card
There should be a slot for the card on the unit .
also you can check on their web page .
Posted on Jan 29, 2009
  • 1111 Answers
SOURCE: magellan maestro 5310. when pluging in th power
yes it can be fixed
you can go here for help
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Posted on Oct 15, 2009
  • 1111 Answers
SOURCE: Need Set-up CD Magellan Maestro 3250
let me say this 1st because this will be the easy way to fix this assuming you tried to either run the update or ran it again after the failure. if thats the case.
im going to assume you tried to update your unit to the 4.46 update that you downloaded off the magellan site,HERE ( if you havent, i suggest you do it before continuing) and in doing so it bricked your unit.
Magellan Will repair or replace any of there gps sytems that were rendered inoperative due to their updates. they will check your account to see if you downloaded the update.
  • register your unit on magellangps.com if you havent already
  • download the update
  • attempt to install update on your computer
  • call magellan tell them your unit is not booting up after the update
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
hopefully you understand what im saying here.
should you decide to take a different route, let me know and i will help you get it up and running if possible.
bill
Posted on Nov 06, 2009
Testimonial: "Great Advise!!! Thank you so much."
  • 1111 Answers
SOURCE: I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
Posted on Nov 09, 2009
Once I updated my Magellan Maestro 4250 the beginning Magellan screen comes on & the bar at the bottom advances like its loading then it stops and freezes. I've tried reseting it without success...
Try re booting, turn off like normal, then when you go to turn it on, hold power button down all the way through the start up, and 15 seconds more than release the on button, now it's rebooted, see if that helps, let me know.
Jun 11, 2011 | Magellan Maestro 4250 GPS
Maestro 4010 screen freezes up when first button pressed. Switch off and restarted but does the same each time.. Where do I get the software to update ?
there is no updates for the magellan 4010 at this time. if you havent tried the reset (little pinhole on the left side) i suggest you try that 1st.
power on your 4010 and after it boots up, use a paper clip to depress the reset switch and let it reboot. that may or may not fix it, because you could have a bad digitizer (the touch part of the lcd)
let me know how you make out.
bill
Dec 15, 2009 | Magellan Maestro 4040 GPS Receiver
Replacing the battery in a magellan maestro 4370
thats a fairly new unit and i doubt if the battery is shot already. it could be, but verify that is shot.
1st verify that its charging. hook up the home or car charger, then go into the main menu, then options, then power options and see if the battery indicator is moving left to right..if it is, its charging. if its not moving and shows a low battery, then its not charging.
if the meter is fully green and shouts off when unplugged form power, i would disconnect the battery then hook it back up and check the charging again
let me know if you still need to replace the battery and ill find you one and tell you how to replace it.
Bill
Nov 18, 2009 | Magellan Maestro Elite 4370 GPS Receiver
Possible to replace broken screen?
i never owned one of these model but every other magellan i have own, the screen could be changed...id see if you can find one on ebay for parts
Jun 24, 2009 | Magellan Maestro 4040 GPS Receiver
I have a Magellan Maestro 4000 ROM wiped. Does not start
try this site..its not an easy fix but it can be done try bricked it the roadmate maestro section...its in there somewhere, i have read it but like i said, its not easy.
http://www.gpspassion.com/forumsen/forum.asp?FORUM_ID=77&sortfield=lastpost&sortorder=0&whichpage=53
May 12, 2009 | Magellan Maestro 4250 GPS
Magellen Maestro 4040 code
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps Updates
  • Magellan 2008/2009 Map Update - NA
  • Magellan Maestro 4040 Voice Upgrade Magellan Maestro 4040 Voice Upgrade Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
    To purchase an Authorization Code you will need to:
    • Login to your existing user account, or create a new Magellan user account.
    • Register your product if you have not already done so.
    • Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
    NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
Help
my gps 4250 would show the blue magellan screen (sometimes the map) the it would completely crash! I paid 500 bucks 4 this ****- plz give me some answers!!!!
Jul 25, 2008 | Magellan Maestro 4040 GPS Receiver
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
363 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
