Question about NorStar T7406 Cordless Phone
Need to put line 4 on a button, they already have L-1,L-2,L-3,HandsFree,Intercom
We have at a customers location 2 cordless sets that use to have L-4 appear and ring on the cordless sets. I cannot get the sets to show the line. I have put a 7416 in each port (23 and 24) and programmed the phone to show the line. When I unplug the phone and plug in the cordless the line does not show up.
Ray
Thank you for your return response. To solve the problem I left the cordless sets plugged in to the base. Then I deleted all the feature keys on the cordless phones where I needed to put the lines. Then I went into the system programming to remove line 3 from one set and programmed L-4 on it. Then moved L-4 to line 4 new button location. Then did the same thing for L-5 and moved it to the next vac. button position. Then I went into programming to add L-3 back onto the L-3 position. And that is how it went.
Posted on May 07, 2008
How to pick the call from other extensions
I have downloaded several manuals for the Avaya by searching online, some are good basic user guides and some very technical. You can pick up a call in several different ways - here is a copy from the manual on call pick ups:
2.2.2 Call Pickup
If you hear another phone ringing, there are a number of ways that you can answer the call if you know the user, group
or line being called.
1.If already on a call, end the call by pressing Drop or put it on hold by either pressing Hold or pressing the
button which the call is on.
2.Press an idle Intercom or Call Appearance button.
· To pickup a call ringing at a particular extension:
Dial 6 followed by the extension number at which the call is ringing or parked.
· To pickup the longest waiting call in a pickup group:
Dial 66 followed by the pickup group number (1 to 4).
· To pickup the call ringing on a particular line:
Dial 68 followed by the two digit line number.
3. You can continue the call handsfree or switch to using the handset or headset (press the HEADSET button).
To Create a Call Pickup Button (ETR 18D/ETR 34D Phone)
1.At the phone press Feature 00.
2.Program Extension: is shown on the display.
3.Press the button that you want to edit or enter a number between 03 to 80 to select a button. The current setting
of the button is displayed.
4.Press the first intercom or call appearance button.
5.Dial 6 followed by the target extension number.
6.The button function is changed to Call Pickup followed by the target extension number.
· Exit programming by pressing Feature 00. You can also exit programming mode by lifting the handset, then
placing it back in the cradle.
To Use a Call Pickup Button
1.Press the Call Pickup programmed button
May 29, 2014 | Avaya Corded Phone avaparp18d
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    When I hit handsfree button it says it is muted cant figure out how to un-mute the phone
    If handsfree is enabled on your telephone, any line or intercom button activates the handsfree, if you press the handsfree button after selecting the line then the button activates handsfree mute, Press the handsfree mute button again to un-mute the line.
    Jul 04, 2010 | NorStar Meridian M7310 Phone
    HOW TO DO A CONFERENCE CALL
    Here are the instructions for making a conference call on a Norstar system.
    Conference [Feature] [3]
    • Establish a conference call between yourself and two other parties.
    1. Make or answer the first call.
    2. Put the first call on hold.
    3. Make or answer the second call.
    4. After the second call is connected, press [Feature] [3].
    5. Press the line or intercom button of the first held call.
    6. Press [Rls] to end the conference call
    • To remove yourself from a conference permanently (unsupervised conference):
      • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
    • To put a conference on hold:
      • Press [Hold]. The other two callers can still talk to each other.
    • To split a conference:
      • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
    • To disconnect one party:
      • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
      • Press the line or intercom button of the remaining caller to resume your conversation.
    • To independently hold two calls:
      • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
    May 14, 2009 | NorStar M7324 Telephone
    PLEASE, PLEASE try and help me...I can't tell you how much this would be appreciated. I have a Panasonic KTS4100 4 line phone (2 corded phones in our office, and one cordless). I have NO IDEA how to use...
    Just in case you missed the manual:
    http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
    There are 2 conditions you need to be aware of
    1 No DSL on the line
    2. Set the intercom extension of the second phone
    By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
    Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
    Carl
    Nov 25, 2008 | Lands Phones
    Intercom
    Are you referring to page all phones?
    you have to put all phones into a ringing group first.
    From extension 10 or 11
    Feature 00
    Left intercom
    Left intercom
    Press #502
    At the group prompt, enter the group number you wish to use (1-4)
    At the extension prompt, enter the extension number you wish to add to the group
    It will say 1-assigned or 2-not assigned
    Press 1 to assign it to the group
    Repeat for all extensions
    Feature 00 when finished
    Now, to page the group, you will press "Intercom *7x (where x is the group number)
    Example, Intercom *71 to page group 1
    If you wish to put that on a button, you must go to each phone.
    At each phone...
    Press Feature 00
    Press the button you want to program
    Press the LEFT intercom button and *71 (for group 1)
    Feature 00
    Repeat at each phone you want the button on.
    Sep 29, 2008 | Lucent PARTNER18 Corded Phone
    Intercom feature not working
    Is one of the 2 phones transformer plugged into a power strip? If so, try putting it directly into the wall, most power strips do not pass the signal properly
    Mar 22, 2008 | GE RCA 4-Line Speakerphone
    2-9450c telephone will not setup
    Each telephone must be connected to line 1 and line 2 for
    proper operation. The remaining lines 3 and 4 may — or may not —
    be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
    Sep 26, 2007 | GE 2-9450C Corded Phone
    My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
    be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
    Aug 29, 2007 | GE 2-9450C Corded Phone
    Remove power cord with no backup battery
    be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set.) Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
    May 17, 2007 | GE 2-9450C Corded Phone
    NorStar T7406 Cordless Phone Logo
    122 people viewed this question
    Top NorStar Lands Phones Experts
    george  peters
    george peters
    dan4261
    Level 1 Expert
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
