Question about GE Televison & Video
When I push the power button on the remote or on the Tv itself, I hear a click as though it is coming on, but the click keeps repeating even though I am not hitting the power button for several times, and there is no picture.
  • 10,515 Answers
Kindly answer the below questions :-
1. Do you hear any sound from the TV?
2. Make and model of the TV?
Thanks!!
Posted on Aug 27, 2010
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Oct 08, 2009 | Televison & Video
Sound will not adjust by remote or on tv itself
check the batteries. Look at your all in one ans see if the tv button is pushed and even on the one for your tv if the have mor than tv option because when you see buttons that TV VCR DVD the right button has to be puhed before they work
Dec 22, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
TV won't power on
I am from Australia and this TV is a dud. We purchased it 12 months ago and it has been to repair twice. It is doing the same as the above message. Prior to this the screen would half, horizontally, go black or white with coloured vertical lines. Never buy another of these.
Dec 22, 2006 | Philips 42PF9966 42 in. HD-Ready Plasma...
TV won't power up
not to alarm you but several models that had the ambilight feature were subjects of the consumer products safety commission recall for shorting in the ambilight feature this can be checked on the us products safety commission website do a google search on your model number assuming the panel is not one of recalls the tv probably needs the power supply board there are several fuses on it ; one that you will find open the fuse shorted for a good reason there is power fet or sumthin on the power pcb dead shorted put in a new board call phillips consumer support and complain that you dropped way too much money on a flat panel tv when you could have bought a dlp tv if thats too complicated buy a new one
Dec 09, 2006 | Philips 42PF9996 42 in. HD-Ready LCD...
Sony KV-32HS510, worked perfect, turned on the next day and all I got is flashing red light.
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Oct 19, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
67 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
