Question about Casio FX-115ES Scientific Calculator
I need to get it in decimal format - Casio FX-115ES Scientific Calculator
  • Casio Master
  • 7,993 Answers
Press [SHIFT][MODE] to display the (SETUP) option selection.
Press [2:LineIO] to select the Line Input/Output format.
Posted on Aug 27, 2010
How do I get answers in decimal format because when I divide I get answer in improper fraction format
You must insert decimal point in equation to get a decimal point in the answer. whole numbers only give whole number sums.
May 22, 2015 | Office Equipment & Supplies
HP 12 C display does not show entire numbers. How do I fix?
If you mean it is not showing everything after the decimal point, you can change that by pressing the [f] key followed by the number of decimal places to display. For example, to restrict it to 2 places, press [f][2]. If you want to see 4 places, press [f][4].
To show all possible decimal places, use the sequence [f][9].
From the manual (http://www.hp.com/ctg/Manual/c00363319.pdf):
"To display a different number of decimal places, press f followed by a digit key (0 through 9) specifying the number of decimal places. In the following examples, notice how the displayed form of the number inside the calculator - 14.87456320 - is rounded to the specified number of digits."
25096057-rvrejqbjq4zuw4cbinsyjvsy-5-0.png "Although nine decimal places were
specified after f, only eight are
displayed since the display can
show a total of only 10 digits. "
The standard display format, plus the specified number of decimal places, remain in effect until you change them; they are not reset each time the calculator is turned on. However, if Continuous Memory is reset, when the calculator is next turned on numbers will be displayed in the standard display format with two decimal places
shown.
If a calculated answer is either too small or too large to be displayed in the standard display format, the display format automatically switches to scientific notation. The display returns to the standard display format for all numbers that can be displayed in that format.
Sep 12, 2014 | HP 12c Calculator
Calculator format is 0.00
By default the calculator is set to display two digits after the decimal point (for dollars and cents). If you'd rather have no digits after the decimal point, press 2nd [FORMAT] 0 .
Alternatively, you can press 2nd [FORMAT] 9 for floating decimal.
Sep 17, 2012 | Texas Instruments BA-II Plus Pro...
How do I change computed display from a fractional format to a decimal format?
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Oct 19, 2010 | Casio FX-115ES Scientific Calculator
How to get answer in decimals instead of fraction
if you do not want to change your settings There are two ways to foecr calculator to display a result in a decimal format.
  1. Before pressing the [=] sign to get the result press [SHIFT] key. thus [SHIFT][=] displays a result in decimal format.
  2. If a result is already displayed and it is not in decimal format (fraction or radical) press the [S<=>D] key to convert it to decimal.
  3. The [S<=>D] key toggles between formats (fraction/radical to decimal and from decimal to fraction or radical depending on the format used in calculation.)
  4. That does not mean that every decimal number can be converted to fractions/radical.
If you want to have all results in decimal format you can configue your calculator to always do so. All it takes is to set LineIO as the default Input/output format.
Press [SHIFT][MODE] to access (Setup) and select [2:LineIO].
Just in case you want to revert to the other IO mode (MthIO)
Press [Shift][MODE][1:MthIO]
Feb 15, 2010 | Casio FX-115ES Scientific Calculator
Fractions to decimals?
To change the displayed result from fraction format to decimal, press the [S<->D] key.
You can also configure the calculator to be in LineIO mode. In this mode, all results are in decimal format.
To set the LineIO mode , press [SHIFT][MODE][2:LineIO]
Hope it helps.
Oct 26, 2009 | Casio fx-300ES Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
Need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Apr 24, 2009 | Texas Instruments BA-II Plus Calculator
Second decimal point isn't displayed
2ND then Format then choose number of decimals then enter
Oct 03, 2008 | Texas Instruments BA-II Plus Calculator
Matrices solutions in fraction format
Press Diamond Enter to convert fractions to decimals.
Jun 14, 2008 | Texas Instruments TI-89 Calculator
Casio FX-115ES Scientific Calculator Logo
35 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
