Question about Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive
Portable hard drive/toshiba
When i used once in my computer it was read as a USB but didnt show me the contents and second time i removed and inserted it wasnt read at all and a burning smell also coming how can i recover my stored data?
could you fix this problem
  • Toshiba Master
  • 27,725 Answers
Your usb card or the usb connecting lead might have shorted out if you smelt something burning and it does ot work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
if you get your portable hard drive to work
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
Posted on Sep 28, 2011
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
Removeable hardrive not loading
Did it get dropped? Have you tried it on another system? Does it sound different than before? Is there any USB device recognition (ie: ding sound, or popup message) when you connect it?
Mar 16, 2014 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
I have a toshiba 2.0GB thumb drive with nothing on it and when i go to get info it shows only 983 KB available!
Your computer may be reserving space on the drive and using it to speed up your memory of your computer. Some have default settings that automatically do this. Try reformating the portable drive to erase the contents and settings and see if this recovers your available space.
Sep 27, 2010 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
How can I get this device to read on an xbox 360?
Step 1: Connect your hard drive to your PC.
Step 2: Create a FAT32 partition on your hard drive. If you’re using less than 32 GB, you can use Windows via “Control panel > Administrative tools > Computer Management”. If you’re using more than 32 GB, you’ll have to use an external program, e.g. Partition Magic.
Step 3: Load all the content you want from your PC onto the external drive. This should consist of files that can be read on the Xbox hard drive.
Step 4: Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port.
Step 5: Go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to read on your Xbox 360.
N.B. Xbox's connection with an external drive is read-only. You can only read files that are already on the drive after connecting. You can't save game files or anything else on the Xbox main drive onto the external hard drive. Also, USB storage devices cannot be used for Xbox live marketplace content.
Apr 12, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
My portable HD when i insert to my computer the motor run and stop imediatly
-The only problem is supply, try to replace your power cable , if your hard drive using only usb cable to get power that is the only you need to replace
- replace your enclosure or housing of your hard drive, possible that your housing already damaged
Feb 05, 2010 | Toshiba 160GB USB 2.0 Portable External...
WD320GB hard drive not working
Are you using a double power USB cable, which normally comes with W/D hard drives?
Also if the light on hard drive blinks the drive is not getting enough power from the USB port.
All the best!
Aug 11, 2009 | Western Digital WD Passport 250GB Portable...
External Hard Drive doesn't work
There is a (laptop-size) hard-drive inside the case, and that hard-drive is failing. As it spins, it generates those noises, like a dying dinosaur. If it still is under warranty, exercise the warranty, and replace it. If the warranty has expired, tough luck.
May 21, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Computer no longer reads drive
It sounds like a permissions issue, allways repair permissions after an update and dont use the machine while installing updates. If it will not repair permissions from disc utility then boot from the install disc, select language and on the page that appears there is a menu bar at the top, select utilities and disc utility and use that.
Apr 03, 2008 | Toshiba 200GB USB 2.0 Portable External...
Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive Logo
217 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
