Question about Dodge Vehicle Parts & Accessories
The security light is flashing as are my lights i dont have an automatic keyless entry remote i unlocked the truck by key and i cant ue drive it it shuts itself off after a couple seconds how do i reset it? etc
  • 857 Answers
Please follow these steps:
•1 Insert the ignition key into the driver side door lock.
•2 Turn the key counterclockwise to unlock the door.
•3 Turn the key clockwise to initiate the alarm activation sequence.
•4 Turn the key counterclockwise. The alarm will stop and reset itself.
Else counsult a repair guy.
Posted on Aug 27, 2010
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
I installed a bulldog remote starter with keyless entry and the doors won't unlock or lock with remote, why?
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
Jan 09, 2013 | Remote Starter with Keyless Entry
RS Focus registered yesterday 19th March Keyless entry but remote fobs do not lock or unlock car. The car was driven back yesterday hav ing now covered 114 miles alarm was going off last night but thats...
should not be using fob buttons for entry or locking for emergency only .if keyless entry walk up to car with fob do not press any buttons see if door opens then walk away from car with fob about 20m then go back to car without fob and see if door locked if so all working fine .indicators will not flash if the above dont work take back to main dealer for diagnostics keys may need to be reprogrammed
Mar 20, 2010 | 2009 Ford Focus
Electrical and lighting problem. Help!
IF DOOR LOCKS LOCK AND UNLOCK.WHILE HAND OPERATING DOOR LOCK SWITCH.YOUR REMOTE KEYLESS BATTERY WEAK.IF DOOR LOCKS DONT WORK BY USING YOUR HANDS TO WORK THE SWITCH.LOOK FOR A BLOWN FUSE OR CIRCUIT BREAKER.
Nov 12, 2009 | 1999 Lincoln Town Car
1997 Maxima : keyless entry will not lock or unlock doors. will lock manually, and will lock by turning the key. hazards do not flash, and the security indicator light does not go solid
Replace the battery in the remote. I have a feeling that it needs to be replaced, after replacing the battery, hold the lock and unlock buttons down for about 7-30 seconds for the remote to understand that it needs to pair with the car. The locks should lock, unlock then lock again.
Aug 17, 2009 | 1997 Nissan Maxima
Keyless entry not working
Try re-programming the remotes, here is the procedure for your car.
JAGUAR
XJ8 Remote Control Programming
1. Unlock the trunk with key.
2. Turn Ignition on.
3. Warning light on dash comes on.
4. When they go out, lift arm rest, inside their is a valley button, Press 5 times within 5 secs of lights on dash going out, Horn & Lights Flash.
5. Press any button on remote, remote programmed
Dec 11, 2008 | 2006 Jaguar XJ8
My car is acting crazy!
" turn the key on engine off 8 times. the doors will lock and unlock. push one of the buttons on the key fob and the doors will lock and unlock. do this for each remote that you have. when you are done turn the key off. the door locks will lock and unlock. the remote fob should work after this."
From My SecuriLock..
Sep 05, 2008 | 2006 Ford Taurus
Vehicle Parts & Accessories Logo
151 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
