Question about Epson PictureMate Photo Printer
My epson picturemate dash pm260 photo printer is printing blanks- I just put a new cartridge in- I noticed the use by date is 8-2011 everything else seems to be working
Basti
  • 1447 Answers
SOURCE: need manual for a epson picturemate deluxe 500
Hi-
If you want the USERGUIDES and MANUALS for this printer, click HERE
Thanks for using Fixya!
Posted on Aug 07, 2008
SOURCE: EPSON PictureMate will not recognise printer cartidge.
This happened to me. I could not get any help. So I swabed the contacts w/alcohol and success!! Mind you, my Picture Mate is over 2 years old, I would not try this w/a printer under warranty unless directed by Epson.
Good Luck
Posted on Dec 30, 2008
yooperbud
  • 8637 Answers
SOURCE: Epson PictureMate personal photo lab
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: please advice why my epson
Take the ink-cartridge out, shake it only very lightly and put it back in the printer. Turn it on and go to the options section and run the printhead cleaner option and alignment, this might make it work properly. Good Luck
Posted on Mar 06, 2009
SOURCE: Epson Stylus Photo R300 sounds like it's printing
I know there are some cleaning cartridges with a chemical thinner that could clean any ink residual that could interfere with proper function of the printing head.
If this doesn't work you probably have to replace the head.
Check also the flat cable that follows the printing head during movement.
Fabio
Posted on Jun 16, 2009
How to clean printhead pm260?
Note: If you see a Print Pack low message on the photo viewer, you may not be able to clean the print head until you replace the Print Pack.
  1. Load paper in PictureMate so you can print a nozzle check pattern after cleaning the print head.
  2. Press Menu.
  3. Press the arrow buttons to select Maintenance and press OK.
  4. Press the arrow buttons to select Auto Cleaning and press OK.
  5. Press OK again to clean the print head. Cleaning takes about 60 seconds. PictureMate makes some noise and you see an Auto Cleaning message.
    When cleaning is complete, PictureMate prints a nozzle check pattern.
  6. Check the pattern to see if there are any gaps in the lines.
  7. Do one of the following:
    • If there are no gaps, Press OK.
    • If there are gaps, Press the Back button.
  8. Follow the instructions on the screen to clean the print head, check the nozzles, and repeat the process as necessary.
If you don't see any improvement after cleaning the print head up to 4 times, turn off the product and wait at least 6 hours. Then try cleaning the print head again. If quality still does not improve, one of the ink cartridges may be old or damaged and needs to be replaced.
Sep 09, 2014 | Epson PictureMate Snap - PM 240 InkJet...
I have an Epson PM260 and it prints but with lines. I have done an auto clean at least 10-12 times and still getting lines. I have a brand new ink cartridge as well and it already says it's low? How do...
Update the printer drivers by downloading them and installing here:http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=90903&infoType=DownloadsDo an auto clean after that. Also look for "cartridge alignment" if available.If that doesn't work, check that the cartridge is installed properly.Otherwise, return to the manufacturer.Please leave a good rating!
Jul 29, 2011 | Epson PictureMate Photo Printer
Can you Help me unclog my nozzle? Epson Picturemate PM240. Head cleaning 3x not successful: no blue ink at all. Print cartridge is brand new and showing 100% full. It tells me to replace the print...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 18, 2011 | Epson PictureMate (C11C556001) InkJet...
All my picture from my Epson Picturemate personal photo printer are coming out pink. I have brought a new cartridge and it is still coming out pink. Why??
Hi!
You need to run a Head Cleaning cycle so printer can get rid of the old ink from your previous cartridge. Try running it from maintenance for at least twice or try printing pictures in between cleaning cycles.
Hope this helps.
May 05, 2011 | Epson PictureMate (C11C556001) InkJet...
Even with a new cartridge it says empty cartridge and won't print
are you using a generic ink cartridge? and just for added information, picturemate cartridges or so some epson inks do have expiration dates, pls check because if you have them stored for quite sometime the tendency is that the inks will harden up. then it will not distribute ink to your nozzle.
another thing troubleshooting steps, have you tried to perform a cleaning cycle? try to do it for about 4 or 5 times. then try to print. pls be advised that it will take in a certain amount of inks to clear the cloggs and force it out.
or before installation of the cartridge, did you shake them? for about 5 times then insert it back
Sep 27, 2009 | Epson PictureMate 500 InkJet Photo Printer
Replaced ink, nothing prints not even tests
there are two main areas of concern: A waste sponge2c905eb.jpg located just under the printhead, and which helps to park the printhead when you turn the power off, and the actual printhead itself. There are also two ribbon connectors that attach to the printhead assembly--and if one of them is not fully plugged in the exact symptoms you describe will occure.
To reach the waste sponge require the dis assembly of the upper half of the printer. I can knock it out is about 5 minutes now! I have used about 50 Q tips to soak up the ink, and manually clan the long rectangular sponge as well.
It you want I can send you pictures of my printer all torn down.
Sep 04, 2009 | Epson PictureMate (C11C556001) InkJet...
Printer is not printing clearly even with brand new cartridge
My PM 260 has been acting up by only printing only about 1" of the paper and then it will stop feeding the paper. It will eject the paper only if I exit from the computer or turn off the power on the printer and then turn it back to on. I already updated the driver (13488). Should I have it looked at by an Epson certified repair or just buy another one?
May 30, 2009 | Epson PictureMate Photo Printer
Message that cartridge is empty, insert a new cartridge.
Hi-
so you mean thats the replacement cartridge and after printing 10 prints it is now saying you have to change it, chances are that is a defective ink cartridge, you should get more prints from that replacement, here's what, call epson technical support at 562-276-1300 and have your proof of purchase ready and complain on this, they will send you a replacement, i mean they should. now if its going to happen on the replacement ink cart, that after 10 prints and it will say its empty then thats an issue with the printer already. update me regarding on it, but for now my best advice is to call epson. Have a nice day!!
May 12, 2008 | Epson PictureMate (C11C556001) InkJet...
Epson PictureMate Photo Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
