Question about Compaq Presario M2000 Notebook
No battery meter on taskbar
I have a Compaq M2000 Laptop, the battery meter no longer shows up on the taskbar. I checked the power setting under Control Panel. I can see the battery meter there, but it never moves to or activates on the taskbar. What can I do to get it back? Also it is operating very slow......... What can I do to speed it up?
No I am not able to see this option in Power option.
Nitul Kr. Bordoloi
Posted on May 26, 2008
  • 37 Answers
Start / control panel / power.
Then you will see a list of options, 'check' the box which says 'always show battery in taskbar'. Or words to that effect.
That'll fix it.
Erik.
Posted on May 16, 2008
2 Suggested Answers
rajkar
  • 21 Answers
SOURCE: M2000 battery and very slow
The Power Options icon wont move to the taskbar. Double click on this icon, this opens the Power Options Properties window. Go to Advanced then select and select and tick Always show icon on the taskbar then apply. This should put the icon in the taskbar.
Try freeing some space using disk cleanup. You can also go to Internet Options to delete files stored in history.
Posted on May 11, 2008
Do compaq presario m2000 laptops have sata ports
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Jan 05, 2013 | Compaq Presario M2000 Notebook
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
M2000 laptop wont power up with power cord used
Check the power adapter with a volt meter to see if it's producing DC voltage.
Oct 28, 2010 | Compaq Presario M2000 Notebook
"battery doesn t charge how do I know if the power cord or the battery is bad on my Presario M2000
If the battery is over a year old then it could be dead.Anything over two years I would bet on it. Usually the power bricks are very reliable. To check it you just need to put a power meter on it and check the voltage against what is printed on the brick. It should be slightly higher.
Without a meter it is pretty hard to check. You should get some indication that it is plugged in. It may have a power light on the brick or the laptop that shows it on even if it wont charge.
Mar 23, 2010 | Compaq Presario M2000 Notebook
MY presario M2000 notebook will not power on.
how about the battery of the laptop, have you aleady check it? if you can find a working identical laptop like the one that try using the battery and see what happens if it will work or not, if it work then you have a battery problem and needs replacement
Nov 28, 2009 | Compaq Presario M2000 Notebook
Compaq M2000 boot
check your memory card(s) you may have a bad on or two, and if that doesn't work then sounds like the mother board has become defective and needs replacing, but the ram Memory would be the cheeper fix first.
Jun 22, 2009 | Compaq Presario M2000 Notebook
Laptop will not start (compaq presario m2000)
Try removing the battery (which may be bad) and only have ac power connected.
RDO
Nov 17, 2008 | Compaq Presario M2000 Notebook
Compaq presario M2000 power cord won't charge my laptop
Check that your power adapter is working fine it may be that the power cable is broken somewhere between the adapter and the laptop. You could try another charger / adapter.
Jul 15, 2008 | Compaq Presario M2000 Notebook
May 06, 2008 | Compaq Presario M2000 Notebook
Compaq M2000 Laptop no Battery meter
Check the Power settings in control panel.
Use msconfig to clear the unwanted programs which are loading during startup. This should make the laptop faster.
Let me know what happens.
May 05, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
136 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
