Question about Frigidaire GLER642A Electric Dryer
Press 'start' button on Frigidaire dryer and timer runs, but, dryer will not spin
    Champion:
  • 245 Answers
You have a snapped belt replace belt problem solved. Rate me if I am correct.
Posted on Aug 27, 2010
My bravo washer is not starting a cycle when I press start button. Also water is still in tub from last load that did not drain.
Sounds like you washer is trying to spin out and becoming unbalanced and cutting off.. Move timer to spin and see if water spins out. If so try running a load and say with it so if it becomes unbalanced you can arrange clothes before returning timer runs out.
Feb 20, 2016 | Maytag Dryers
Frigidaire FFLE2022MW washer dryer combo beeps twice and stops during all washing cycles after it fills with water and lid is still locked. Does anyone know how to correct this? Thanks
Thank you for your inquiry, Criss Ard!
From my understanding you are having issues with your Frigidaire laundry center not starting a cycle. You stated that the washer fills with water then locks. It sounds like your timer is not advancing and that could be due to a faulty timer or wiring harness. You may want to perform a reset on your laundry center and you can do that by disconnecting the power cord for roughly ten minutes. If this troubleshooting step does not help resolve your issue you may want to consult with a professional technician for proper repairs. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire White Electric Washer And Dryer...
DRYER WONT SPIN
Can you hear the motor run after you attempt to start dryer? If so, check for a broken belt. If not you will need futher troubleshooting, Could be motor, timer, etc.
Mar 29, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Model glg331as4 will not tumble
Does the motor run and it won't spin or does it not respond when you press the start button?
Nov 21, 2012 | Frigidaire FGQ332ES Gas Dryer
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer won't start once button pushed.
most of the time this is caused by the centrifical switch you can take the dryer apart and clean the motor some times this will fix if not replace the motor try setting the timer to 60 min open the door hold down the door button and give the drum a good spin clockwise but watch your hand so the drum dont rap your nuckles
Mar 31, 2009 | Frigidaire Dryers
High efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Mar 22, 2009 | Frigidaire FEQ332E Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
