Question about Royal VF1012mx Shredder
How to disassemble the feeder unit and manually unclog the paper sensor.
    Genius:
  • 1,218 Answers
Remove the waste bin...remove 4 screws you can access once the waste bin is removed.
Remove the cutting head...remove screws from the bottom of the cutting head and open it up.
Posted on Oct 06, 2010
What happens if you pull a paper jam from feeder, the opposite direction that your support to?
There are usually a number of paper guides and sensor arms that will tear into the paper if pulled the wrong way.
This can leave paper fragments in the fuser causing further jams, temperature sensor malfunctions, or odd marks on the print, and small pieces of paper left in the fuser usually require disassembling the unit to clean it out.
At worst case one or more sensor arms could be dislocated or broken which can be difficult or expensive to replace.
Nov 14, 2014 | Xante Ilumina 502 GS Digital Color Press...
Brother mfc8440
yes there was a sensor switch, which can be broken and faulty that needs to be repair or replace.
Sep 07, 2008 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
It pulls the paper in stronger on the right side and then gets stuck.
check the paper feeder if have a foreign object.. you must disassemble the unit to see the paper feeder clearly.
Jan 02, 2011 | Dell 922 All-In-One InkJet Printer
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
Machine keeps saying paper out
You have one of the paper path sensors stuck, or broken. I'm afraid this is a repair center issue, unless you are familiar with the disassembling of the unit. Good luck.
Be blessed.
Aug 05, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Aurora as1015cd
Some shredders have optical sensors with a dark sensor LED on one side of the slot, and a clear transmitter LED on the other. You will most likely have to disassemble the shredder housing to clean them.
MAKE SURE TO UNPLUG THE UNIT.
Generally you will find screws on the underside of the shredder unit, with one screw covered by a "warranty void if broken" sticker. Remove these screws, separate the housing, and clean the optical sensor pair with windex or isopropyl rubbing alcohol. If your shredder has a CD slot, it may have its own sensor pair. Be sure to clean both pairs of sensors, as the CD sensors seem to be the ones that have the most trouble because of small aluminum debris.
May 12, 2008 | Office Equipment & Supplies
My brother laser printer HL-5050's paper light is flashing, which usually indicates a paper jam. i've checked 5 times and there is no paper jam. have shut off printer and restarted 3x. when i try to print,...
Hi
I've nearly the same problem....My printer(HL5050)  takes only a little bit of the sheet, then paper led flashes.
I've found a block into the paper feeder. This printer is impossible to disassemble.!!...even if I've the service manual, because for taking away a simple pressed paper block , it's necessary disassembling  almost all the machine!!! No comment
So I'd an idea:
I've sprayed into the paper feeder a great quantity of a cleaning spray (without oil) , in order to get the paper block wet, then , by means a school-book plastic cover, used like a paper sheet,  and  manually acting on the gear, I've pulled this plastic sheet up and down several time (spraying in the same time)in order to  remove these hard paper blocks. Now my feeder seems free. Tomorrow I'll try to test it.....
Regards
PS To do this it's necessary the only removal of left cover, in order to reach the gear which allows the paper to advance manually.
Apr 21, 2008 | Office Equipment & Supplies
Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Jun 14, 2007 | Royal VF1012mx Shredder
Royal VF1012mx Shredder Logo
381 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
