Question about Sony Grand WEGA KF-50WE620 Television
I HAVE A BLUE STRIPE ACROSS THE BOTTOM ABOUT 3" THICK AFTER IT IS ON FOR AWHILE IT MOVES UP TO THE MIDDLE OF THE SCREEN, ALSO HAD A DARK BLUE TRIANGLE THAT STAYS IN THE BOTTOM RITH CORNER, DOES NOT MOVE. THIS HAPPENED WHEN WE MOVED THE T.V. TO ANOTHER HOUSE, THOUGHT WE WERE VERY CAREFUL BUT I GUESS NOT. WE LAYED IT ON ITS BACK WITH BLANKETS.....SERVICE GUY WANTS $100 JUST TO LOOK AT IT, SONY SERVICE SAYS I AM DESCRIBING "OPTICAL BLOCK"
5 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Sony with blue screen
make sure you are on tv slection and not video1 ,aux . pull up menu go to setup look for cable/air make sure you are in tv mode not video aux.if this does not fix it then you may have bad tuner.
Posted on Jan 17, 2008
Agent Dort
  • 216 Answers
SOURCE: red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link http://download.jazel.net/misc/filecache/b8/b89bca4c8b740315d378e8ed030461c5_1227-517SeriesOwnersGuide.pdf and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 25, 2008
SOURCE: Sony Grand Wega kdf-42we655
you have to replace the optical block.The lamp in this type of tv is too close to the optical block and it gets to hot.
Posted on May 08, 2009
who ever has problem with rear pj tv's here a simple thing that the manufactoring wont tell that there are vents on these units and filter that needs to be cleaned every month and if you have hairy pets more often. the thing that happening is the system is getting no air
and the lcd is burning up i know this because i've taking them apart
over and over its the same reaction you get for leaving you laptop pc in the sun or in cold weather. extreme enviroment is the culprit. if you see these problems its big money other wise cleaning these vents and filter gives you long life to lamp and the lcds difsusion plate would do something else.
Posted on May 14, 2009
Turned on my TV today to find a 5" horizontal stripe across the middle of my screen. I can view the picture through the stripe but the picture brightness on the top 1/3 and bottom 1/3 of the screen is much...
This sounds like an impact injury to the screen itself. It is likely that something may have hit the screen or if the set is old, the part inside may be starting to go.
Hope this helps
Nov 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
I have had a Sony KF-WS60S1 rear projection TV for some 3 years and recently had to replace the globe. I completed this as per the book, double checking all screws were tight and the globe inserted...
You will need to pull out the engine and check for any smudge on the lens. then proceed with the polarizers 3 of them they are sitting in front of the DLP chips, this is a delicates operation. the blue polarizer is the one which usually suffers burn-in (dark spots on the glass). if everything looks ok, then it means that the dlp chips are faulty, at that stage it will be uneconomical to be fixed.
Hope this helps!
please rate me!
Mar 19, 2009 | Sony Televison & Video
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
