Question about Kenmore 62802 Electric Dryer
My dryer runs but it won't heat up to dry the clothes. It worked until my sister brought it to me yesterday. Could something have happened to it during travel?
    Champion:
  • 245 Answers
Classic, Check your breaker box. It will be the one with the double breaker. If one side pops it will run with no heat. Rate me if I helped. I just saved you a 100 bucks or so.
Posted on Aug 27, 2010
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Won't start and overheating
Hi Beverly Johnson...
Your problem is possibly a Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Sep 19, 2012 | Whirlpool Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
Tumble dryer will not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
Aug 19, 2009 | Dryers
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
Aug 05, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore 62802 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
