Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How do i set the dial tone from tone to pulse
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest your select it from the list beginning here to download a copy of the manual.
Posted on Dec 14, 2012
  • kakima Dec 14, 2012
  • 7 Answers
SOURCE: Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Posted on Nov 10, 2007
shaggyrat
  • 1224 Answers
SOURCE: how can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Posted on Jun 01, 2008
  • 11 Answers
SOURCE: I can't figure out how
Uniden 2.4 GHz whats this
Posted on Aug 26, 2008
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
Posted on May 13, 2009
smartr10U
  • 1305 Answers
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Posted on Jun 05, 2009
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
Won't dial out
might you have your phone set for tone on a pulse line???
Do you know what kind of line you have?
You can use pulse and/or tone on a tone line. But you cannot use tone on a pulse line.
A pulse line is cheaper ... I have a pulse line from the mid 70's and I refuse to upgrade it (costs more) to tone - whats the point - I never get any calls and im not in that big a hurry to dial for the extra couple bucks they want.
Oct 13, 2009 | Lands Phones
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
Dec 06, 2007 | GEH5450 Cordless Phone
Cordless telephone sw/from pulse to tone
In General Electric (GE):
TONE/PULSE DIALING
Nov 25, 2007 | GEH5450 Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
