Question about GE GBS18KBP Bottom Freezer Refrigerator
No I need to know how to change fan motor freezer is fine.fridge on top is warm.fan motor not running.How do I get to it?
  • GE Master
  • 43,501 Answers
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 28, 2010
FRT125GW warm fridge problem
Hello jumptrout51 - Generally speaking, if the compressor is on then the freezer fan should be on as well. Note that it does not indicate a failed fan motor. The fan motor receives power from the temperature thermostat. Therefore, at this point, I would personally recommend connecting with an experienced technician to determine the underlying cause.
Apr 19, 2013 | Frigidaire FRT125GW (12 cu. ft.) Top...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Top section of fridge and top part of freezer are cool to warm, bottom part of both fridge and freezer are freezing.
Hi, Check and see if the evaporator fan motor is running in the freezer section. If it is not running while the compressor is running, you will need to change it. Also check and see if there is any frost building up on the rear freezer wall. If there is frost, you will need to replace 1 of 3 defrost parts. let me know if it is a defrost issue and I can instruct you on testing the parts.
Please let me know if I can assist you further.
Vic
Jul 13, 2009 | Refrigerators
Warm fridge frosty freezer
Hi. thanks for the question . check the freezer fan motor, is it running . is there frost build up in freezer, check that. pull fridge away from wall. remove back panel .clean all lint . thanks the appliance doc
Sep 17, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer okay, fridge warm
i suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Refrigerators
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 106.72102100 Not cooling URGENT!
behind the back panel that you pulled off is where the compressor is. on the left side of the compressor is where the relay/overload is plugged in. its gone bad. if you touch the compressor it will either be really really hot or room temp. unplug it let the compressor cool and replace the relay/overload to fix your problem
Nov 27, 2007 | Kenmore 65812
Cold freezer warm fridge.
That sound was the evaporator fan motor in the freezer. This circulates the cold air from the freezer into the fresh food section. If this is not running you need to check for power to it. If the fan has power to it but not running, replace it. It should be located behind freezers back wall inside of freezer near top.
Oct 09, 2007 | Refrigerators
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
GE GBS18KBP Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
