Question about Samsung SpinPoint M60 HM120JC 120 GB Hard Drive
Samsung hm120jc hhd not workinmg. I have changed the disks I/F card with a woirking card but it is still not working. Appreciate your response Lolu
2 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: my samsung hm120jc hhd is not working.though t was
There are a few reasons this would happen, The options are a bad USB cable, a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians test it with a new USB cable, if it works buy the new cable. If that also fails to work have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Posted on Nov 04, 2009
Hi I have a Acer Travelmate 4050. The MB bios does not pick up the HHD. Wen I startup using my Windows XP cd It does pick up the HHD I can then Format and the installation will copy the files to the...
If the BIOS does not detect the hard disk and Windows XP cannot detect the hard disk to install Windows, then the hard disk is faulty.
To get your Acer working agai, you need to replace this hard disk with a new one.
Apr 21, 2011 | Acer Computers & Internet
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device displays the standard green light. I tried connecting the device to...
Most of these problems are associated with an I.C. on the board that governs the HHD. Unfortunately, the chip gets pitted (overheats) on the GaAs and is ruined. The green light (LED) on the HHD will turn on as it is getting power but the main chip that controls the HHD no longer works thus rendering the HHD inoperative.
Bottom line, get a new external drive. Should you get the same model or something similar to what type of electronic hardware you have, you can remove the new HHD and put your old HHD in its place and you will see that all of your data is still intact.
Apr 12, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Hi IMy seagate barracuda 500gb internal hhd has sector 0 bad.No way with many program to resolve it.I can' format,always say me that there is a bad sector.I used seagate tools,hhd disk repair and othen...
Since the HDD has rejected easy repair by the most appropriate tools, I recommend you recover the data and replace the drive. I've been through this many times for clients.
You did all the right things.
Best Wishes
Aug 04, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
MY MONITOR IS NOT WORKINMG RIGHT
how u mean not working right if ur using onboard graphic it could of gone and then u need to add graphic card to ur pc if allready got graphic card in that may have gone and nead to renew it if all else fails it would be the monitor with probs try another moniter
Jan 15, 2010 | Computers & Internet
My samsung hm120jc hhd is not working.though t was working first.my com says usb drive not recocnessed. please help me . suggest me driver download
Chris
Nov 03, 2009 | Samsung SpinPoint M60 HM120JC 120 GB Hard...
My external Samsung HM120JC 120 GB Hard Drive not responding
Not sure what could be the problem.
There are many issues here.
- Did this drive worked before?
- If it did, was this your boot drive?
- USB cable and connector problems
- How is this connected to the drive?
- Is it in a package that came with the drive complete, or you had to install it?
My two cents... Samsung and other Japanese drives are not that reliable and if it's new, return it and get a Seagate drive. They have five year warranty and much better drives.
Apr 08, 2009 | Computers & Internet
My PC hard disk is always out of space why
Windows Xp itself requires 4-4.5GB plus any other applications softwares, basiclly you should have 6GB for all of the software before any other software.
for WIndows Vista that requirement is around 7GB.
you need to clear up the HHD via accessories>>system>>disk clear. select all of the item listed. defrag the HHD after cleaning.you may have to perform the defrag serval time before yu get to a reasonable area. ideally you should have 15% of free space on your HHD.
if yu can't create enough free sapce, tehn you should consider buying a larger HHD.
Mar 27, 2009 | Microsoft Windows XP Professional
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Samsung SHR-1040 O/S and Video format/file
the only way to do this is to directly back up the video to your pc from the unit. mj
Apr 10, 2008 | Samsung 4 Channel Dvr
Error to Detect, hardisk must be formatted
The problem might not be with the HHD instead it could be your bios setup. you will have to download drivers for the bios of you laptop and install them in your operating system then try to access the hard-disk.
Mar 12, 2008 | Computers & Internet
Samsung SpinPoint M60 HM120JC 120 GB Hard Drive Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
