I have an AVOL 22" Multisystem TV/DVD combo.During our move the movers lost the power cord from the TV to the wall. Power; DC12V=5A 60W ALTD 2230M Ser #TL22D4804562. Do you have one I can buy. Jim: morrisonjamesr@yahoo.com
  • 308 Answers
SOURCE: Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
A common problem with this model are leaky transistors in the relay drive circuit that powers on the TV. That is electrical leakage, not anything physical you can see. The transistors should be labeled Q1701 and Q1702, and would have to be replaced by soldering, so a trip to a repair shop may be necessary. The DVD uses a standby power supply I believe, which is why it appears to work OK.
Posted on Feb 11, 2007
SOURCE: Lost factory remote
you need the remonte control original bath this situesen you need the selection deader cod four your remont controler
Posted on Jul 12, 2007
SOURCE: Remote control for Orion 9 inch tv dvd combo
Hi Beth,
The remote that I have for this tv has part number 076R0HE04B on the back. If you google it you should get some results to buy a replacement.
Hope this helps,
Kelly.
Posted on Jun 07, 2008
  • 3 Answers
SOURCE: magnavox mwc24t5b
The power supply is shutting down for one reason or another. This unit has 4 shutdown alarms feeding the main processor. It doesn't take much to trip it and believe me, it's a ***** to find it if it is a subtle condition. The VCR could be shutting it down as well if it is not reset exactly right.
This is what I did with the one unit I worked on; It would shut down after 5 seconds. The picture was good when it breifly came on -- but it shut down anyway.
IC1601 is the shutdown opto isolator that will shut off the supply. I removed it and the set came on. After a few minutes one of the power supply diodes started smoking so I unplugged it. The diode, D1618 was bad so I replaced it and the TV worked. But, I could not put IC1601 back in without it still shutting down. I spent hours searching and couldn't find anything. Since it was my son's TV (which he found at the dump) it was OK by me. BUT, if you remove this IC, (it is a four pin located near the yellow transformer) the set will come on no matter what. Just remember, if there is a problem, it will show up quickly. Maybe a new troubleshooting method? Ohms law troubleshooting? No, unfortunately not. Just be careful and try to find the problem.
If you google this model number, you will find a free schematic that --someone-- uploaded to a free schematic website.
Posted on Nov 08, 2008
SOURCE: lost remote for akai tv/vcr/dvd set
my, need code for programation my combo in remote control rca
Posted on Jan 11, 2009
I need a power cord...where can I get one?
Something like this. Make sure you order the right plug and make sure yours has a figure 8 connector to the back of your television.
UpBright NEW AC Power Cord Cable Plug For RCA 22 26 32 40 42 inch Series...
Jan 01, 2016 | Iview International 22 inch LED TV with...
I have an advent tv/dvd combo. I dont have a remote and its stuck on video. how can I put it on tv without the remote? thank you
Disconnect the TV\DVD combo from power source (A\C) for two to three days, Replug power cord & see if it returns to normal. 2nd attempt:: Unplug A\C power from wall and take a piece of bear wire or any metal (paper clip, screw driver ) and SHORT the two blades of A\C plug for at least one FULL day.DO NOT PLUG INTO a\c SOCKET FOR ANY REASON !!! After one full day, take the short accross the blades. Replug into A\C power socket. see if that fixes the problem. P.S. Your TV should have a button that switches from TV to DVD play right in the right front.
Jun 19, 2011 | Recoton Advent Advent DV1418A 14 in....
I need a dc power cord for my skyworth tv..can't find one
just buy any 12VDC power supply with 5A rating and then just change the connector with the same size on type.
Jan 17, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
A\\VOL Model ALTD1902M - Where to Find Power Cable?
POWER: AC 100V-240V at 50/60 Hertz means that your unit has a switching power supply built in which will operate on ANY AC (alternating current) voltage from 100V up to 240V, on either 50 or 60 hertz frequency.
(110V @ 60 Hertz is an USA wall outlet power standard, whereas 220V @ 50 Hertz is the European wall outlet power standard)
So, you can actually use it with just about any line voltage from a standard home wall power outlet, you just need the correct power cable that fits into your unit on one side and into the wall socket on the other.
The 60W power rating is just telling you how much power the unit consumes for operation which means that if you hook it to a 110V power line (USA), it will draw a current of approximately 0,54 amperes (60 watts divided by 110 volts equals to 0,54545 amperes) and if you hook it to a 230V power line (Europe), it will draw a current of approximately 0,26 amperes (60 watts divided by 230 volts equals to 0,26086 amperes).
The switching power supply in the unit has an internal fuse which is rated somewhat above the 0,54 amperes, could be a 0,63 amperes, but most probably it is rated at about 1 ampere or more.
If the specs you listed are correct, you only need to worry about the correct power cable that will fit into your wall socket on one side and into the combo unit on the other.
Hopefully, if the unit is in good health, you haven't wasted your money after all.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Televison & Video
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
Help to find power cord
circut city or radio shack maybe a gamestop 2
Feb 01, 2009 | Computers & Internet
No indication of power what so ever
Yes, a computer power cord is the same.
Without physical sign of damage, it will be hard to induce the movers to cover the problem. You will need to take it into a reputable TV shop and get their evaluation that whatever is wrong is due to the move. Its odd that it failed while off, however of course all these new TVs are not near as reliable as the old ones. Might just be a dislodged connector inside.
Hope Ya Fix It!
Jan 24, 2008 | Samsung PS42P2S 42 in. Plasma Television
Power cord
call customer service - the number is on your owner's manual [dxh]
Dec 27, 2007 | GoVideo T2040 20 in. LCD Television
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
