Question about Panasonic PT-51G54 51" Rear Projection Television
I have a Panasonic rear projection tv Model# PT-51G54A that the picture is very dark on. I've tried turning up all in-set settings with the factory remote, but was not enough to fix the problem. What can you tell me? Thanks for your help up front!
Please tell me what to do if the picture is to dark.
Posted on Oct 06, 2010
Dark picture
Please check your TV's Picture mode setting. Use the VIVID picture mode to achieve the brightness video.
Mar 11, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Picture is dark and not clear the set is a49e
Hi, Try to change settings (contrast or brightness). If that does not help replace bulb in back of TV.
Good luck.
Jun 13, 2011 | Panasonic PT-47WX49 47" Rear Projection...
I need to reset lamp on PT-52LCX16 Panasonic rear projection tv how do I do that
MODEL INDICATED DOES NOT USE A "LAMP", IT IS A CRT (picture tube---has red, green and blue picture tubes).
Verify model number is or is not correct.
What is problem with this set?
SD TECH
Aug 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic Projection TV
If you are using your TV's internal speakers, then you have a loose connection inside your TV more than likely on your audio output IC. Re solder all connections on your audio output IC's. To locate your IC, trace your speaker wire back to the circuit board.
Feb 23, 2008 | Televison & Video
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-51G54 51" Rear Projection Television Logo
295 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
