Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Will not drain in spin cycle and has a LE error code on display
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE error means the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
LE LIGHT IS APPEAR
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 12, 2012 | Washing Machines
LE LIGHTY IS PRESENT
LE error on LG 2277HW
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Oct 15, 2012 | LG WM-2277HW Front Load Washer
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Hope this helps.
Jun 29, 2011 | LG Washing Machines
Displays an LE error code - what does this mean and how do I fix it?
Codes for LG/Kenmore washers:
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
FYI:
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Also:
Problem:
An occasional LE error but always a slow or no spin: Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
I have service manual and more here
Jan 16, 2011 | Washing Machines
What does LE mean?
Nov 28, 2010 | LG WM-2277HW Front Load Washer
My washing machine is cannot spin ,it show error code LE
Nov 28, 2010 | Washing Machines
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Apr 13, 2010 | LG WM1814CW Front Load Washer
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
