Question about Kenmore 95002 / 95004 Electric Kitchen Range
The heat control on one of my burners on my smooth top range doesn't work correctly. The burner is only on when control is turned all the way up, lowering the control turns off burner
  • 139 Answers
The burner; control/switch is bad /unplug range ..pull knob off burner control to see srews..remove back panel on range..1/4 inch srews are used ....look at all them wires an switches ..wow ..locate the bad switch ...buy a new switch from appliance parts store /or one from a used appliance store ..make sure you have the make /and model/serial # off of the range... to get the right switch ...install switch.. remove one wire at a time when installing switch or wright down how it is wired ...let me know ..good luck/joe/
Posted on Aug 27, 2010
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
What cause one of the burner to over heat on my frigidaire stove
depends on type or range top you have. it is rather the switch is not regulating properly, could be if its a smooth top the sencor in the element is malfunctioning and not regulating the element. make and model type is important to be more direct for answering this question. sorry.
Oct 10, 2014 | Frigidaire Kitchen Ranges
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Jan 24, 2010 | Kenmore Kitchen Ranges
Burner not working
This is an easy repairr and you can save a lot of money by doing this yourself. This sounds like your infinite switch burned your burner element out and you CAN do this!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7AM until 7PM CST and we will provide part removal/installation instructions when you purchase your parts through us.
We look forward to getting your range top cooking properly again soon, so call us when you need us.
Thanks, Ella :)
Dec 29, 2009 | Kitchen Ranges
Most smooth top elements only work on high
this is a voltage distribution issue
you would be better served to replace the
ERC
Electronic Range Control
Sep 29, 2009 | Kitchen Ranges
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner works on high (9), loses heat at medium (5)
The control is bad. I assume the burner worked on the other side?
eric
Jul 03, 2009 | Kitchen Ranges
Burner seems to be wired backwards
You have to access the underside of the cook top. Does the back right work correctly? If so switch the wires on the back left to match the right burner.
Jul 01, 2009 | Kitchen Ranges
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
96 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
