Question about ASUS P4P800 SE (890552603657) Motherboard
How do you test the LPT1 port? It does not recognize my printer. I know my printer works and the printer cable is good.
  • ASUS Master
  • 27,725 Answers
Control panel,administrive tools,device manager,ports, find it there
good luck
Posted on Aug 27, 2010
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Tip
General Printer Troubleshooting: Make sure the printer has power and is ...
<b>General Printer Troubleshooting:</b> <ul> <li>Make sure the printer has power and is on-line. If you are using a manual printer sharing device, make sure the switch is set to activate the correct printer.</li> <li>Turn it off and on again to reinitialize any internal settings that may have gone astray.</li> <li>Ensure that the tape that seals the cartridge ink port is removed prior to installing the cartridge.</li> <li>Use the printer's own self-test, according to the manufacturer's recommendation. If it fails, you have verified that the problem is within the printer. If the print head is not moving at all, the transport motor may have failed.</li> <li>If the printer that you are using is not set as the default printer in Windows or the printer driver is not installed, the printer may print garbled characters. You may also receive errors when you attempt to print from applications.</li> <li>If the printer passes the self-test, try a test print using the Print Screen capability within DOS. If the Print Screen fails, you know the problem is in the relationship between the printer and the computer. Inspect the cable and the cable connections. Replacing the cable with a known good cable is worth trying since cables are so frequently the source of printer problems. Cables can fail with broken wires, loose or broken pins, or incorrect pin-outs.</li> <li>If the printer is connected to the computer through an add-in device, remove the add-in device and connect the parallel cable to the printer and then directly to the port on the back of the computer. Some examples of add-in devices are: switchboxes, parallel port scanners, external disk drives, external tape drives, security lock keys, or external CD-ROM drives. Some add-in devices may interfere with proper communications with the printer. Try printing again. If the printer prints successfully, the cable may not have been connected properly, or the add-in device may have been interrupting communication with the printer.</li> <li>If the combined length of the cables connecting the add-in device and the printer exceeds 10 feet, communication can also be disrupted. In addition, the software that controls some add-in devices may take control of the printer port interfering with any other device attempting to use the same port. In some cases, the software for the add-in device should be disabled or uninstalled. Remove any add-in devices and uninstall the software for those devices, then try printing again.</li> <li>The message "out of paper" is sometimes erroneously reported when there is plenty of paper, and can indicate a physical problem with the printer.</li> <li>If the printer port is not properly identified in CMOS, the printer may not function properly and you may receive errors when trying to print. Check your User's Guide on how to enter CMOS. Once in the Setup utility, locate the LPT1 settings. The address setting for the LPT1 port should be 3BCh or 378h depending on what kind of video card you have. The IRQ setting for the port should be 7 and LPT1 should be enabled in order for the printer to print correctly.</li></ul>
on Mar 31, 2011 | Office Equipment & Supplies
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Hp deskjet 9650 not compatible with Vista 64-bit
Hp Deskjet 9650 printer owner, sorry to inform that there is no Microsoft Windows Vista operating system printer driver solution available for your printer. But there is an alternative way to workaround it so that you can do basic printing with your printer.
As a workaround, an alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer. However you might find that some of the product features are no longer available when using this alternate printer driver, but that is your best option right now.
The alternative HP printer driver that will work with your printer is HP Deskjet 9800.
The Next thing you do is: Install the driver for HP deskjet 9800
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click Start , click Settings , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (deskjet 9800) and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of the printer, if desired.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12. For USB connected printer, please proceed to step three . For Parallel port connected printer, please proceed to step four .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Next is: Configure the printer
1. In the printer folder, right-click on the name of the printer and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to the newly created USB port, click Apply .
Last step: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Good luck Cheers!!!
Apr 26, 2009 | HP DESKJET PRINTER, HP OR COMPATIBLE
Oki C5150 Not Communicating with Computer
lpt1 usually only works for parrallel printers unless a USB port has been mapped as lpt1.
Is this being installed on a Windows Vista computer?
Jun 19, 2008 | OKI C5100n Laser Printer
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
My Printer EPSON TM-U220 does not print....HELP!!!!!
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Jan 14, 2008 | Epson TM-U220 Matrix Printer
Printing
Is the printer connected via USB or a printer cable to the LPT1 port? Make sure the Port setting in the properties of the printer are set to the correct port. If the printer is plugged into the USB port but the properties say it is on the LPT1 port. the cpmputer will think it is sending something to the printer but the printer doesnt know it.
Apr 03, 2007 | HP DeskJet 940cxi InkJet Printer
Computer will not recognize printer
* access your BIOS setup during booting. look for USB options and enable them if they are not properly enable/set. * try to update/reinstall,replace the printer driver.
Nov 26, 2006 | HP DeskJet 697c InkJet Printer
ASUS P4P800 SE (890552603657) Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
