Since we had a new consumer unit with trip switches fitted with 100DP isolator and 30mA RCD, our Smeg 90cm Duel fuel cooker trips it when the main oven is on. The top oven and grill work fine, but as soon as the main oven reaches it's required temperature, it trips the box, we flip the switch to return the supply and it then can do it a couple of times more . We are going to get the main cut-out fuse upgraded from 80A to 100A and the meter upgraded to 100 amps from 40amps. Do you think that this will solve our problem, or do you think it is a problem with the oven itself? Our electrician did a full circuit survey and did not find anything wrong with either the appliance or the supply. But, he isn't a domestic repair electrician. Any advice gratefully received. Thanks.
  • 828 Answers
Someone should check the current draw by the appliance. Then compare it with the name plate to determine if the problem is with the appliance or external power supply.
Posted on May 06, 2008
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Aug 13, 2013 | Smeg Ovens
Opening oven door trips rcd when up to temp. doesnt do it when cold
Nov 22, 2011 | Smeg SE290X Stainless Steel Electric...
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
How to fit a fan element for a smeg se335ss-5 oven
Jan 31, 2011 | Smeg SC712U Oven
RCD trips after different period of time
Sounds more like a fault developing as the cable heats up due to poor connections.trip operates about 30Ma ot .03 0f an amp which is a pest but good in its own right.If you referring to one socket then remove that socket and check for any loose burning leads,Check the fusebox again for any of the above, good idea to run an independant earth around 10 mm cable to main box just in case earthing is bad..hope you get on ok.
Apr 01, 2010 | Dryers
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
