Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
We haven't used the heater for about a month. When I tried to fire it up tonight I got a message on the panel that indicated that it needed service to clean a filter. Then it attempted to light, but even though I could smell gas and hear the ignitor it did not light.
  • 310 Answers
This tells me that the pressure switch is not activating. It either means that the pump is not moving enough water through the heater, or the due to the heater sitting without use, the pressure switch is clogged or failed. Easy part to switch , cheap to buy. E-mail me if you need help.
adamh@newconceptchem.com
Posted on Oct 28, 2010
My Dayton heater will not fire up and tries to fire and then shuts down tries to fire and shuts down blows smoke out the end
Check noggle for dirt, check fuel filter for dirt. Check al rubber hoses for leaks, Set air pressure All these will cause it not fire.
Dec 28, 2014 | Dayton Heating & Cooling
Leaking coolant fluid a good amount almost a stream when I shout the jeep off near the fire wall on my jeep liberty. Temp gauge is reading fine
You have a bad heater core it needs to be replaced soon, your system cannot maintain pressure and you will have massive issues and failures due to this and you will have to replace alot more than just your heater core. I hope this helps you
Dec 14, 2013 | 2002 Jeep Liberty
I need to be able to send pictures again as i was up untill approx two or three weeks ago. About then out of the blue microsoft office email progam appears when i try to send a picture but i canot send...
When in IE > Tools > Internet Options > Programs tab > In Internet Programs section what do you have as Email program?
Can you select "Outlook Express" in Drop-down menu of Email option?
Try setting OE and score this solution.
Nov 15, 2010 | Microsoft Office Outlook 2003 for PC
Have a SHB 20LC Focal Point fire with Optiflame Elite that has the flame effect motor not working and requires a new motor as indicated by a technician, but he has said that he can not source a motor. Can...
I have exactly the same problem, light effect just went out tonight. Trying to work out if it is the motor or that little tiny cream box fixed to the terminals inside. If I take it out the lights come on. Just about to see if the motor is working, just that box that has gone.
Aug 05, 2010 | Dimplex Compact Electric Flame Stove...
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
Runs for about 15 minutes then shuts off .
I believe the pump setting is 6.0 for the 155 BTU model. I will know more after tonight, we are using a Reddy Heater 155 unit tonight at church. I will look on the side panel and see what the PSI should be for the pump pressure and respond either tonight or tomorrow.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
263 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
