Question about KitchenAid Dishwashers
My Kitchen Aid two drawer dishwasher started not draining all the water out, Then a few days later it would not stop running., both drawers. It only stopped when the circuit breaker was turned off. What is wrong? Does this dishwasher has a cancel button?
  • 338 Answers
SOURCE: Works then no power Kenmore 16352
first thought would be a loose connection in the junction box under the dishwasher.
Posted on Nov 28, 2008
  • 38 Answers
SOURCE: The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Posted on Feb 23, 2009
jmgldsmth
  • 1906 Answers
SOURCE: GU1500XTLS3 Periodically won't start. Dishwasher
in the front left bottom of the tub is a float switch; it sometimes is under a cover with a screw securing it it looks like a big round ball shaped piece of plastic and on the bottom of this float there's a pin going down a hole in the tub (the float pin sits on the switch and, water lifting up and down on the float moves the switch: listen for a distinct "click" as you move the float up and, down
you see; the float rises as the water fills the dishwasher tub closing the float switch and, signaling the washer to start cleaning the dishes
some times dirt prevents movement of the float but,waiting usually displaces the dirt/soap etc. just enough to make it work again until the float pin gets encrusted again the cure is to clean the float pin
Posted on Aug 31, 2009
pappapumpdaf
  • 635 Answers
SOURCE: Dishwasher not getting enough water in either
This sounds like a hard water deposit problem.
Check your water inlet valve for a screen and see if its clogged. Also it may just be a water valve/solenoid problem. As in, it's too crusted up to float up and down.
Some models have a water fill timer, while others use a water fill/pressure switch. This may also bear inspection.
The beep you hear during your cycle is indicating that your water level is too low to cover the heating element, which can cause cracking and lead to a short.
Posted on Mar 07, 2010
heatman101
  • 43501 Answers
SOURCE: Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 30, 2010
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Upper drawer dishwasher won't drain
First =check for a plugged drain line
Second = check for plugged screens in the unit.
It could also be your pump. The vanes are only plastic and they sometimes just give out.
Jan 07, 2014 | KitchenAid Kitchen-Aid KUDD03DTSS...
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
When running one draw water collects in unused drawer
I would recommend that you check the dishwasher installation instructions to check if the water inlet and outlet are properly set up. Look at page 4.
If this is happening only with bottom drawer after top drawer is run, then it could be a leaking door seal. But if it happens with both drawers, then it is a bit un usual and could be due to a backflow in the drain hose.
If you are using inskerator in the sink, then make sure it is not filled up.
Hope this helps.
Aug 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
189 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
