Question about Philips Philishave Micro Action HQ 4806 Electric Shaver
I require new cutting blades for my philishave4000 modelHQ4401
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 95 Answers
Philips norelco HQ56 replacement heads for philipshave 4000 model hq4401 blades replacement parts.
i require new cutting blades for my philishave4000 - ff0302dc-13b4-41fa-8c2d-63f49226609e.jpg
Posted on Sep 17, 2013
  • 8,197 Answers
You can get the shaver heads on the link below.
http://www.abtecparts.com/commerce/search/products/?product_id=05XPHhq43&merchant_id=1933
Good Luck and please rate 4 thumbs up for the free answer
Posted on Aug 27, 2010
Overlocker the blades wont cut where can i but new blades
You may be able to find a replacement blade. Search the internet for:
Make + Model + the word "blade"
or contact manufacturer support.
Most of the time, only one blade can be replaced by a lay person. The other blade requires some technical skill (to assure accurate placement and timing), so you will most likely need to take it for service. Consult your owner's manual.
Apr 23, 2016 | Sewing Machines
Why did it suddenly stop cutting?
Please provide the model of your machine.
Ok, it's a serger. Wondered why a sewing machine would be cutting unless it had the cut-n-sew accessory.
Most likely the blades are damaged or malfunctioning. Is the blade still moving when it is stitching? Is it just chomping away at the fabric but not cutting? If so, either or both blades need to be replaced. Consult your owner's manual. Usually only one blade can be installed without any technical knowledge. You can probably order the replacement blade and install it yourself. However, the other usually needs to be replaced by a knowledgeable technician because it requires some precision.
Has the blade stopped moving at all? If so, how long has it been since a thorough cleaning and oiling? Take it for service.
Mar 25, 2016 | Elna Sewing Machines
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I...
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Jul 12, 2009 | Saws
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
New dado set understand the shimms and chipper work
The shims are placed between the blades and chippers in a stack. they are used to make very small adjustments to the final dado width... So usually you set up your dado set for a specific width of cut according to your blade chart, then make a test cut... If you need to widen the cut very slightly, add some shims in between the blades as required to get a good fit on whatever material you are joining or putting into the dado etc.
Hope that makes sense!
Please rate this solution on FixYa!
Apr 12, 2009 | Delta 35 7670 8" Stacked Dado Set
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
New Home LOCK 778
Any sewing machine store should have or be able to obtain these blades for you. You should only need one because one of them is a carbide steel blade(Very Hard). It will have a dark color on the cutting part of the blade.Replace the other one.
sewman7
Jul 08, 2008 | New Home 104D Mechanical Sewing Machine
Philips Philishave Micro Action HQ 4806 Electric Shaver Logo
125 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
