Question about Health & Beauty
I just got this iron and it didnt have any directions or helpful tips. Can you help?
  • 8,197 Answers
May I get the make and model # so I can help you more
Posted on Aug 27, 2010
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
How do i use this product(Weller model Standard 7200)?
You need the nuts that hold the tip in the iron--slide them on, then bend the ends sideways with pliers and leave about 1/4" sticking out sideways. Be sure to make the upper and lower bends in the same direction. Be sure to tin the new tip with solder when you first heat the tip. Hope this helps!
Sep 30, 2010 | Weller Standard Tip: 7200
G1490 just stopped working. Second identical iron that just stopped working. Can manufacturer replace the iron free of charge?
Most have an 800 number and are willing to make replacements directly to the consumer...call them and find out...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 09, 2010 | Euro-Pro Shark GI490 Iron
CANT SEEM TO ADJUST WATER TO FALL DIRECTLY ON BLADE...GOES TO EITHER SIDE OF BLADE AND MAKES FOR A DUSTY CUT, HAVE ADJUSTED THE NOZZLE AND CLEANED THE TIP BUT SAME RESULT, ARE THESE RIDGID SAWS DESIGNED...
tile dust collects in the cast iron housing that the tip screws into. A sewing needle will help after you remove the guard to clear the orifice from both directions and then flush until desired effect is achieved.
Mar 06, 2010 | Saws
Iron will not turn on
heatman101
Jan 27, 2010 | Euro-Pro G1490 Continuous Iron
My iron won't heat up
This tip is for cloth irons, but the principles are all the same...
heatman101
Dec 06, 2009 | Waring WMK300 Professional Belgian Waffle...
Should I use distilled water in iron or just regular. I got this iron w/no directions
It is best to use bottled spring water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 04, 2009 | Black & Decker Steam Xpress AS250 Iron...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
