Question about RCA P52960 52" Rear Projection Television
What was the price of the original RCA P52731wk
Need Price for RCA TV, 1998, Model F20352SE
I can only get you close, your model does not come up. 1998 price or a 27 inch, general size, would be around 290 dollars
Mar 12, 2014 | RCA Televison & Video
Rca p52731wk convergence issues
e089e5b2-9394-4ed6-9a51-c32a90d091bc.jpgWhat you describe is known as a convergence board problem. Its a fairly common problem. You can read more about it herein this Fixya Tip.
http://www.fixya.com/support/r4581251-convergence_failure_test
Feb 22, 2013 | RCA Televison & Video
I have model RCS P52731wk. No power when i puch the power button on the front. Is there an internal fuse?
THERE IS A FUSE, it is located inside where the power cord connects.
Let me ask does power light come on for just a moment at all?
SD TECH
Nov 03, 2010 | RCA P52960 52" Rear Projection Television
Is there a reset button for rca tv model p52731wk
You can try a hard reset with this model. It requires unplugging it and leaving it unplugged for at least four hours. There are numerous set codes for this model, but it all depends upon the problem you are experiencing. There is no singular "reset button," though, as the system was simply too complex in its day to warrant one.
May 09, 2010 | Televison & Video
My T.V. won't come on.
I would guess that the HV Block has failed. A very common failure. I would hesitate trying to replace it unless you are familiar with Projection HV circuits. You did good supplying
the Model # and Chassi #. both are required to get the proper part# if you try to get the part yourself or calling a service shop to fix it.
Hope this helps,
Skyassoc
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
I have a 1994 RCA projector TV model# p52731wk. The picture is all blue. How do I change the bulbs?
Unless you have a source for the tubes then I can help, however, those tubes have not been available for over 4 years now. I recommend start looking into a new one or see if you can locate a refurbished projection set from your local Television Repair Center.
Apr 23, 2009 | Televison & Video
Rca p52731wk wont power on
check for bad or broken connections around the high voltage transformer......
Feb 24, 2009 | RCA P52960 52" Rear Projection Television
My rca p52731wk projection television will not power on
We are available for conference Today and Everyday. Wewill assist you in repairing your set. The Part you need is Transformer 226094. Please joinin conference for part price and location
LOGIN
Circuitcity
Dec 26, 2008 | RCA P52960 52" Rear Projection Television
RCA Home Theatre Wide Screen TV Model# P52731WK
This sounds to me like the parameters are off, I recomend only a service tech adjust this for you because the parameters can only be accessed by a service man, and they are critical, if done wrong the whole set can go out of wack.
Aug 15, 2007 | RCA 32V420T 32" TV
RCA P52960 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
