Question about Magic Chef 31000 Gas Kitchen Range
My parents range has a code that saids F5 .there was no wiring diagram to see what the codes are
  • 139 Answers
Look for the diagram it will be taped in a enevelope /remove oven door /drawer.. it should be their where the drawer was off to the side .. somewhere..use a flashlight to see.. its their ..let me know ..good luck../joe/
Posted on Aug 27, 2010
  • joe harper
    joe harper Aug 27, 2010
    or look under the range top... for the burners ..to see if it is their also
What does the code"F5E2" mean when trying to use the self-cleaning function?
This error means that the door lock didn't engage properly. This could be a wiring problem or a problem with the switch. First disconnect the range from power and check the wiring and switches from the control to the switch and back. If the door was locked when the F5E2 error was observed, then replace the door switch.
If the door was not locked, then check the door switch and the latch switch. Replace the bad switch.
The rear door switch is part W10107830, https://www.partstore.com/Part/Maytag/Maytag/MER7765WW/Whirlpool/Whirlpool/W10107830/New.aspx . A useful parts diagram is here: http://www.searspartsdirect.com/model-part/mer7775ww0/3048/0124111/W0908230/00003.html .
After replacing the bad part, reconnect the power to the range. Press and hold any key for a minute to clear the F5 code from the memory. Then press Cancel to clear the next code you see. Check if the range works.
I hope this helps.
Dec 23, 2015 | Maytag MER7765WW Freestanding Smoothtop...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Whirlpool oven question...FSEO on display after about 5 mins of oven operation..beeps continuously,oven shuts off...dinner ruined!
If you receive error codes F5-E0, F5-E1 or F5-E2, the door and latch switch need checking and possible replacement.
The door switch is #12 in the diagram (click image for zoom)...
Hope this helps.
Jun 22, 2011 | Whirlpool RF364 Electric Kitchen Range
E1 F5 code after self clean cycle. its been 12 hours and wont unlock and still says code
Hi.
E1 and F5 (F5-E1) means that the Self clean latch will not lock. The problem is usually fixed replacing the door latch. If the door latch is working, check wiring to door latch. The control module causing the error is not very common but possible. If the latch and wiring are OK, check control board.
Here troubleshooting from manual:
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Here parts and diagrams: arrow_link.gif KERC507EAL1
Regards.
Ginko
Jun 18, 2011 | KitchenAid KERC507 Electric Kitchen Range
We ran the self clean program and now have E-1 F5 on the screen and the oven is locked .
The best way to find the meanings of the codes is to unplug it, pull the back off of the control panel, and look for the folded paper wiring diagram that the manufacturers place in there. It usually has the codes and diagnostic tests printed on it. Hope this helps.
Feb 14, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
Self cleaning oven codes F5 E1 when on clean cycle
Feb 14, 2011 | KitchenAid KERC507 Electric Kitchen Range
I have an E1 F5 code on my stove and the oven door is locked. What is this code and how do I clear it?
hello,
The E1 F5 is an error code indicating that water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you have to do to fix up this is to unscrew (open)ranger then trace the wire down to the reader sensor/panel clean all form of water and dirt around them after all this make sure that all wire are in there position mostly on the panel then couple it back as it was with this the problem of E1 F5 is solve please do this with care
thank you.
Jun 11, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
F1-7 code
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 07, 2010 | Jenn-Air SCE30600 Slide-In Electric...
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
I justt recieve ur answer
It is not the temperature probe.
I have sent you a message afterward, I guess you did not receive it, that is because of a system problem.
I repeat here my additional message:
Sorry about my first diagnoisys, I looked into the service manual, E1 - F5 fault code means that you have aproblem with the door switch or latch assembly.
See also:
E1 f5 error code whirlpool
Fixitnow.com Samurai Appliance
To fix it follow the instructions below:
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct."
from error code E1 F5 door lock
Dec 05, 2008 | Whirlpool GS460 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
