Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
Dish detergent does not wash off dishes and gets baked on in the dry cycle. Using cascade complete.
  • Maytag Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 29, 2010
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
When I wash the dishes whether it is liquid or powder cascade soap the dishes come out woth a white filmy substance. What causes that?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Mar 25, 2011 | Maytag Dishwashers
My dishes come out with a powdery coating on them and cutlery is not always clean. I use cascade and jet dry but this still does not help. Whyis this happening?
Hi
Daniel
Feb 20, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
My cloths stink from the washing machine. I did
yes
get a box of dish detergent crystals
do one empty load with 1 cup of the crytals
cold is better but warm works too
the mold is old soap in the machine
if your using more than 1 tablspoon you using way tro much soap cut back and once a monthe doo the dish detergent load
the dry the grey boot between loads
make sure the drain in the boot is clear
Oct 07, 2009 | Asko W6021 Front Load Washer
Dish Washer soap does not dispense during wash
You don;t list the make and model number or its aproximate age.
The simpelest cause is switching to an ultra-cheap dry detergent. Recommed you use a name brand powder (like Electrosol or Cascade) Never use gel or tablets, ever.
Check all spray arms for blockages. Now is a good time to remove the filter (non trivial but do-able on most dishwashers.)
Clean empty dishwasher by filling a bowl or large cup with white vinegar and placing it in the dish rack. Run a short cycle with no detergent added. You may need to repeat.
If problems persist, the pump motor is probably failing. Schedule a service call or consider replacement of DW. Good Luck!
Mar 29, 2009 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag dishwasher DWU7560AAM
Check your water spray bars. I'll bet they are plugged with calcium or something.
Oct 13, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
57 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
