Question about TalkSwitch CT.TS001.124001.US Full-Featured PBX Telephone System
Talkwitch 240VS and TS400 phone
I have caller ID and when a phone call comes through I can see the number but talkswitch adds 1 in front of the number and therefore I am unable to store these numbers or ring the people directly back.... can anyone help please.
To setup the phone to automatically insert your external dial group (usually '0') before numbers, so you can save them in your phone book, and make calls from your missed / received call logs, you should check the TS400 manual.
For the TS350i you do this 1) press transfer/menu button 2) Press 4 - Call preferences menu 3) Press 8 - Access Code Prefix 4) Enter the number you use for outgoing calls (usually 0) 5) Press OK
Posted on Jul 27, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Phone adds #1 to local calls in caller ID
talk with your service provider
if the number 1 is placed before a local number then logically when calling that number, the number would be recognized as a local number and be charged as such
Form what you say , if the number was from a caller in a different state and the number was prefixed by say 6 then the system would recognize that as a long distance call
again talk with your service provider and if accurate contact your state governor or senator and make an issue of the law requiring the prefix number on caller id
Nov 21, 2017 | Panasonic KX-TG5439 5.8 GHz Dual Handset...
Caller ID dOESN'T wORK
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Jul 06, 2009 | TalkSwitch CT.TS001.124001.US...
Sci phone sms caller id not working. Only the
When saving a contact to your phone book for some reason you have to save the number with a "1" in front of the area code and number or it will not register as the contact calling. I would save a number and have them call or send text but it just kept coming up as the number itself and not their name. I changed the number with the 1 in front of it and it worked just fine.
Jun 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
External caller ID does not display on either line talkswitch 284
Click File> Save
Jun 18, 2009 | TalkSwitch CT.TS001.124001.US...
CALLER ID - REDIAL LD NUMBER
Press the caller id and get the number you want, then press the star button, that will add the 1 for long distance dialing.
Jun 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
Talkswitch 480 VS no longer shows caller ID Simply "out of area".Can this be repaired?
Call Talkswitch, they will offer a swap for another system and bill you $500 to do so. This happened to me twice. First swap was $250. A year later it is now $500. I was told this increase was due the end of the system life and a shortage on parts. My system is just about 4 years old. My next system will have telephone line surge supperssors inline with the telephone lines.
May 29, 2009 | TalkSwitch 480vs Phone
Talkswitch caller ID from outside calls not working
Click File> Save
May 06, 2009 | TalkSwitch CT.TS001.124001.US...
Somethings wrong!
Sorry to have to ask all these questions, but they are necessary to try to help figure out what is going on. I need to know what TalkSwitch system model you are using and what version of software it is running. A system serial number is required if I need to contact my distributor. If you could provide the current configuration file on the system, that may help as well.
I am an authorized TalkSwitch Partner and will try to assist you.
Sep 28, 2007 | TalkSwitch TS-400 Phone
TalkSwitch CT.TS001.124001.US Full-Featured PBX Telephone System Logo
206 people viewed this question
Top TalkSwitch Lands Phones Experts
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
