Question about LG Flatron L1710S 17" LCD Monitor
My LG Flatron 1710S computer screen doesn't have any power. Sometimes the power light will start flashing but most of the time it stays blank.
    Sergeant:
  • 223 Answers
This is a common issue, the power supplies in LCD monitors fail prematurely. (if your monitor has an internal power supply) , Double check all your power connections, but it sounds like the internal supply is toast, (its a simple capacitor replacement to fix, but cost to do this job seems to always outweigh a new monitor purchase) sorry to be the bearer of bad news.If you find my answer helpful albeit poor news, please use the thumbs up feedback.
Posted on Aug 26, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble. Thanks! Gurvy
My lg t705sh monitor start after 45 minites of the power on
i am also having the same model,but mine was just power light blinking and screen is blank even not starting after long hours.
Sep 14, 2010 | LG Flatron F700B 17" CRT Monitor
The monitor LG Flatron L 1710S turns ON only for 1 sec and then turns Off. If  turn  On  again is  the  same
You may have capacitor failure (bulging or leaking) in the power supply (very common problems in ALL monitors), failed transistors or transformers in the back light inverter circuits, or bad lamps due to poor solder connections, poor solder joints on PCB. You need to open it up and look inside, post back what you see so we can guide you further. See example of failed monitors for guide: http://s807.photobucket.com/home/budm/allalbums
Mar 25, 2010 | LG Flatron L1710S 17" LCD Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG FLATRON L1732S Problem
Hi...there,
Well, It's time to retired this LCD... Your panel it busted! Treat yourself a new monitor... Happy holidays!
Dec 05, 2008 | LG Flatron L1750S 17" LCD Monitor
LG1717S - Power light flashing - no image.
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 03, 2008 | LG L1717S-BN 17" LCD Monitor
LG Flatron L1951S-SN 19 in. Flat Panel picture problem
When the picture disappears again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 15, 2007 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG Flatron L1710S 17" LCD Monitor Logo
298 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
