Question about KitchenAid KESS907SSS Electric Kitchen Range
I have a Kitchenaid Kess907sss00 Range and water overflowed on cooktop and got into control panel. Now the control panel doesn't lite up and oven doesn't work. What can I do?
5 Suggested Answers
SOURCE: Water on cooktop leaked into control panel
Sounds like you got water into the touchpad. If so there is no easy way to dry it out. It might dry itself out but you might up having to buy a new one.
Posted on Jul 21, 2007
  • 1314 Answers
SOURCE: Maytag electric range will not work
you have a house power promblem turn off the range at the breakers and start at where the cord connects to the range check it there then go back to the breakers all the eyes are on their circutes so it has to be at the power source feeding them
Posted on Jul 14, 2008
  • 41 Answers
SOURCE: Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
Posted on Aug 28, 2009
milten1
  • 1304 Answers
SOURCE: Pot overflowed on cooktop and water went into
yea i would repalce the erc, or clock or electrical panal, wheere the water got inot, the top is powered off the selector switches from a direct feed from one leg of your outlet,
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5149232
\part 3 is hwat your looking for
i wish there were better news, you may be able to find a used one on ebay too
go to www3.sears.com
type in your model it will se be part 3
but you will have a national part number
hope this helps
Posted on Nov 01, 2009
Stopped during self clean--already replaced thermal fuse---it appears cooling fan was never connected, and it does not work once connected. All other functions appear to work, except power to the fan
Is the control panel completely dead?? If the cooling fan under the cooktop was not working, in most cases the main control board or control transformer if it is separate will get heat damaged and need replaced. That cooling fan is there to keep everything from over heating mainly during clean but should come on during normal baking if it gets too hot under the cooktop.
Apr 30, 2015 | KitchenAid KESS908SPS Electric Kitchen...
Red light on stove surface is lite up red and code pf is on display
"PF" displayed on the control:
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Apr 04, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
Kgst307gbs glass control panel replacement
KitchenAid is the most likely source of a replacement
Mar 23, 2013 | KitchenAid KGSS907SSS - Slide-In Gas Range...
Pot overflowed on cooktop and water went into electrical panel. Range doesnt work but cooktop still does. I unplugged it, took apart control panel and put it back and it still doesn't work. Any...
hope this helps
Nov 01, 2009 | KitchenAid KESS907SSS Electric Kitchen...
Door Locked on and can't remove after water spill
At this point it is very likely the control panel will need to be replaced. If you had disconnected the power and let it dry completely before trying to use it it may have been ok except for the cosmetic issues. You might still try unplugging it for a half hour or shut down the circuit breaker for that amount of time. I am thinking it won't help but it is worth a try. I don't know what to tell you about the cobweb looking damage.
Jan 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
KITCHENAID KESS908SPW ELECTRIC RANGE
are you sure the oven doesnt need 2 voltage supplies?control voltage and load voltage.
Aug 12, 2007 | KitchenAid KESS908SPB / KESS908SPW...
Jun 14, 2007 | KitchenAid KESC307 Electric Kitchen Range
Open Questions:
See all KitchenAid KESS907SSS Electric Kitchen Range Questions
KitchenAid KESS907SSS Electric Kitchen Range Logo
113 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
