Question about Mag Innovision LT576s 15" Flat Panel LCD Monitor
MAG innovision LT-926W 900W problem! After I turn on my computer, the screen immediately begins to flash and then goes black. The power is still on thought and so is my computer. If I take a flash light and aim at the screen, I'm able to see what I was doing before it went black. I usually have to shut my screen on and off around ten times for it to stay on for a good hour and then I need to repeat the process and it gets very frustrating. It was bought in 2006 or 2007. Please help! I'm starting school soon and I need my computer!! Thank you very much!!!!
    Sergeant:
  • 223 Answers
This means your power inverter inside the monitor is dead. This little gizmo lights up the monitor backlight. They dont fail all at once, but slowly die and give problems like you describe, you can order these online for your monitor , or find one on ebay for under 30 dollars, but unfortunately there is no fix, other than replacing the inverter. sorry. Please use the thumbs up rating if you find my answer helpful, albeit bad news. Take care. .
Posted on Aug 26, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble. Thanks! Gurvy
I have a mag lt 2219 and everytine I turn it on it goes black
moz-screenshot.jpgHello Chris,
You have a monitor with a common problem. After a few years some LCD monitors will blown a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, iff so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 18, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
Black screen
It is most likely that the filter capacitors on the power inverter board have failed. I took mine apart and found seven swollen capacitors on the this board, they fail prematurely and seem to be the only thing wrong with the unit. I replaced them and now it is working just fine.
six 470uf 25v electrolytic capacitors and one 220uf 25v Capacitor.
you should not attempt to repair this yourself unless you have some electronics training since there is a shock hazzard involved and also these capacitors will blow apart if they are installed incorrectly (very messy experience).
Jan 31, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
I need the driver for mag multivision LT 926W
Any monitor should be plug n play. You can plug it in to a port on your computer and it will work.
Jan 29, 2009 | Computers & Internet
Hi there, I have a monitor MAG LT755s, i do not who to plug in power. I do not see anywhere there is a hole to plug in
its on the back underneaf a little ledge, if you have to flip the screen around and look up at it from the bottom. Hope this helps.
Dec 12, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Monitor Message = "No Signal"
see i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Apr 24, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Mar 08, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
MAG L765b Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision 765S Screen Flashes on and off.
It sounds like it is trying to re-synchronize it self and not going back the the default setting. Compare the resolution of the game to your monitor capabilities.
Jerome
Dec 29, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Waking up monitor
probably ur compuet may be in standby so u have to beat the keyboard to wake it up .
Dec 05, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT576s 15" Flat Panel LCD Monitor Logo
748 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
