Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
How do i put the bag back on, lost the instructions
I lost my instructions for pattern 5527 (diaper bag). Can you help?
You could contact Simplicity and see if they can help.
or find a free diaper bag pattern on line and use as a guide.
bags arent too difficilt, usually need to interface well, attach pockets, straps, then sew lining to top edge wrong side to wrong side, leaving a bit of the lining or side seam open so you can get inside to attach lining seam allowances to bag seam allowances to hold together.
Simplicity 5527 Diaper Bag in Three Sizes
Feb 28, 2015 | Sewing Machines
Seiko westminster whittington
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Apr 05, 2014 | Home
Putting in new coil
i rotate the flywheel to the magnet the place a piece of a brown paper bag between the coil and the magnet
May 12, 2012 | Garden
I have a Gaggia Ice cream maker but i have lost the instructions - do you know where i can get another copy please? Margaret
Do you need instructions for the mix or do you want instruction for how to freeze the mix?
Receipts should be easy.
As far as freezing, you need ice and salt. Probably one bag of ice and 5 lbs of salt.
Place the canister in the contailer. Crush some ice up ... pack it around the base about 2 inches deep. Put in a layer of salt. Repeat this until you are full --- Ice - salt - ice - salt etc. When you get to the top, stop plug in or start cranking. When the motor stalls or when your arm falls off, stop. Have your younger assistant put a towel over the top. Make sure the drain is open. Let the mix 'cure'. Go recover. Come back in 20 - 30 minutes and enjoy your ice cream.
I hope you find this to be of value. Enjoy your Ice Crean!
A
Sep 24, 2009 | Ice Cream Makers
INstructions for rival chocolate fountain
you need about 2/3 cup of oil to 1 bag of chocolate chips (i think we use about 3 bags). In a bowl with the oil and chocoloate chips, melt them in the microwave about a minute at a time until its all liquid DO NOT over cook the chocolate chips in the microwave, they will scorch. Once melted pour into the fountain and turn it on. I would do one bag at a time. Hope this helps!
Jul 05, 2009 | Kitchen Appliances - Others
Want insturtion book and bag # for vaccim #086355 upright and bag size
your vacuum takes a type U bag oem part # 3920750001 and the belt is a style 4&5 belt
May 26, 2009 | Vacuums
Simplicity # 8748AWT lost instructions, help!!
BEWARE!!!! This crib has been RECALLED. Please do not use.
Dec 07, 2008 | Baby Gear
Lost instruction manual
hi minkymouse..try this link i got for you..
http://www.premaxx.com/en/products/baby-bag/manual.aspx
hope this helps
-mox
Nov 23, 2008 | Baby Gear
Need hardware for childesign madison convertible crib
bad new the company  closed about 3yr ago
Oct 14, 2007 | Childesigns Madison Crib
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
42 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
