Question about Nintendo Wii Console
Trying to connect to internet getting error 52232
    Novelist:
  • 142 Answers
The info listed below is from Nintendo's official web site.
Error Code: 52232 There appears to be an issue with your wireless router's firewall.
  1. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
  2. If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls, click here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
I hope the info listed above has helped in some way.
If possible please rate this solution.
Posted on Aug 26, 2010
2 Suggested Answers
  • 219 Answers
SOURCE: trying to hock up the
Unable to connect to your wireless network
Likely cause: Your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii.
Solution: Manually assign an IP address and DNS to the Wii.
  1. Manually assign an IP address to your Wii console.
      Assigning an IP address to your Wii is easy!
    1. Access the Wii System settings and select "Internet" from Page 2.
    2. Select "Connection Settings" and choose the connection file you currently use (will have a red border around it).
    3. Select "Change Settings," and click the right blue arrow twice to reach "Auto-Obtain IP Address."
    4. Click on "No" and select "Advanced Settings."
    5. Now, click in the "IP Address" field to enter an IP address. Look at the brand of your router, and enter the IP address listed below into the field.
      • Linksys - enter: 192.168.001.140
      • Netgear - enter: 192.168.001.250
      • Belkin - enter: 192.168.002.090
      • D-Link - enter: 192.168.000.190
      • Apple - enter: 010.000.001.250
      • 2Wire - enter: 192.168.001.250
      • Actiontec - enter: 192.168.001.250
      • SMC Networks - enter: 192.168.002.190
      • Don't see your router brand listed? Click here for help with finding an IP address to enter.
    6. Once the IP address is entered, select "OK."
    7. Select the Subnet Mask box, then enter 255.255.255.0 and select "OK."
    8. Select the Default Router box. You will need to enter the defail gateway address for your router brand. Look at the brand of your router, and enter the gateway address listed below into the field.
      • Linksys - enter: 192.168.001.001
      • Netgear - enter: 192.168.001.001
      • Belkin - enter: 192.168.002.001
      • D-Link - enter: 192.168.000.001
      • Apple - enter: 010.000.001.253
      • 2Wire - enter: 192.168.001.254
      • Actiontec - enter: 192.168.001.001
      • SMC Networks - enter: 192.168.002.001
    9. Select "Confirm" but DO NOT select "Save."
    10. Tap the right arrow to reach the page ro "Auto Obtain DNS."
    11. Select "No" and then "Advanced Settings."
    12. Click into the "Primary DNS" field and enter: 008.008.008.008
    13. Click into the "Secondary DNS" field and enter: 008.008.004.004 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    14. Select "Confirm," and then "Save."
    15. Click on "Save" and then "OK" to perform a connection test.
    16. If the test was successful, then your Wii is now connected online. If you received error code 52130, please call 1-800-255-3700 so that we may assist you further.
  2. Other suggestions:
    • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
    • Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
Please, do not forget to rate my answer
Posted on Jul 06, 2011
Tablet won't let me open anything. Bought from a garage sale and she reset it and now it won't work. I tried opening google play and it still wouldn't connect
Because you keep getting "an internet connection error" it sounds like it is not connected to the internet. I would try to address that problem first. I would go in and delete the wifi connection and re-add it using the correct network name and passphrase for your wireless access point. I think that once you get the internet connection error to go away, you will have better results with internet-dependent functions like the app store. Also make sure you don't have airplane mode or other feature activated that would turn off the wifi.
Nov 26, 2014 | Tablets & eReaders
How can I fix my majicjack plus to work with anew service provider?
tab_l.gif Answer tab_r.gif If you hear error 1 while trying to place a call with your magicJack, it means that you are not connected to the Internet.
You need to check your new internet connection first.
Then sign into
You must check your new internet connection gets to magicjack.com
sign into VoIP Phone Service Internet Home Phone Service Providers magicJack
Jul 12, 2014 | magicjack.com
Error code 52230 Can not connect up on wii to
This error is an issue with your router's firewall. You can find Nintendo's help on this error here:
http://www.wiierrorcodes.com/wii-error-52230-52232.php
One of the best ways to fix this would be to set up a static IP address on your Wii that is outside of the DHCP range of the router and then open up your router settings and configure a DMZ to point to that IP address. This will place your Wii completely outside of the firewall.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 09, 2011 | Nintendo Wii Console
Trying to hock up the wii get error 52232
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
Copy and paste this link or Click Here for it
This particular code has a lengthy troubleshooting process. Besides my personal input, I think the above website will assist you in the step-by-step process to correct this error. If you need assistance going through this or needs clarification, don't hesitate to ask. I'll be happy to help you through this.
Thank you I hope this information helps you,
Regards,
Nico
Jul 06, 2011 | Nintendo Wii Console
My wii is not picking up my wi fi conetion and it said that my error code was 52232. It said to visit this website for assistance, so if you can send me some helpful facts that would be great!!
The Wii is not connecting or finding your wifi because of a firewall issue with your wireless router. Your wireless router is set to broadcast on channel 6. The Wii wants a certain channel though. I had this same issue when I set up my Wii.
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6.
The following link will give you a default settings page for each brand of routers. Select your brand and model and it will give you a url to get to the settings. The information you need is found in the "Broadcast Channel:" area.
http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
Jun 10, 2011 | Nintendo Wii Console
What does error code 52230 mean
from the website: http://www.wiierrorcodes.com/wii-error-52230-52232.php
This error is caused by an issue with the firewall of your wireless router.
To solve this error :
If you are using America Online (AOL) broadboad, you may experience problems connecting the Wii console to the internet. Please contact America Online for more assistance.
If you are using wireless routers with Comcast firmware, you may experience problems connecting the Wii console to the internet because of incompatibilities with the Wii console.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
Mar 28, 2011 | Nintendo Wii Console
Error code;52232
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52232&system=Wii&locale=lang
Dec 28, 2010 | Nintendo Wii Console
When i try to connect to the internet through my playstion 3 it says 80130182 error i have internet through my computer and i have been trying to get the ps3 internet to work for about a week what does...
that error code is a generic "cant connect to the internet" code. try reseting your router and you should be fine. if not try opening your NAT connection on your routers settings.
Dec 14, 2009 | Sony Playstation 3 (PS3) Console
The wii is unable to connect to internet
It seems that it can't establish communication to your access point.
Nintendo Forum explanation:
Wii Error Code Group: 52020, 52021, 52022
Summary: Connection difficulty with either router or modem.
If automatic configuration is not working (it expects DHCP to anser; i.e. to get an assigned IP address) try manual configuration. Enter the values as you would on your PC to connect to the network.
Consult the Nintendo Forums for detailed help.
Jun 12, 2008 | Nintendo Wii Console
Psp no connection to internet
Why can't I connect to the internet on my psp I tried over & over nothing it says the connection to the acces point has timed out..
i still can't connect even with wireless router
Jan 27, 2008 | Sony PlayStation Portable (PSP) Console
Nintendo Wii Console Logo
1,125 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
