Question about RCA P61960 61" Rear Projection Television
DON'T HAVE ANY PROBLEMS BUT IS IT HDMI? - RCA P61960 61" Rear Projection Television
  • 1,512 Answers
G'Day
Although you TV does not have HDMI inputs, you can get an adaptor from here to allow you to plug a HDMI connector into your TV. This will solve the problem for you. Could be a huge cost saving for you, to get the feature without having to upgrade your set. Cheers
regards robotek
Posted on Aug 29, 2010
  • RCA Master
  • 3,866 Answers
I am afraid this TV does not have hdmi ports, The hdmi port on tv's did not come out until later, so unfortunately its not hdmi,
thanks for your questions.
please do be considerate and leave feed back and ratings for your free answer today.
Posted on Aug 26, 2010
HDMI`S DON`T WORK ON VIZIO TV
The HDMI controller is bad. The easiest "work around" is to use the "Component" connectors instead. The only downside is you get no higher than 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people are only seeing 1080P when viewing Blu-Ray discs. Cheapest alternative is to buy an "HDMI to Component" converter, which will let you connect multiple HDMI connectors to one box, and then have one set of Component connectors coming out of the box. You select different "sources" on the box itself.
Mar 07, 2016 | Vizio Televison & Video
Why is HDMI 1 and 2 video quality poor?
Resumed, check HDMI contacts. If they are ok, maybe your cable is not good. Try another cable
Now, there is lot of information about issue:
Common HDMI problems and solutions
Solving HDMI Problems
Does HDMI cable quality actually affect transmission
1080 TV HDMI to HDMI connected to pc bad quality
Expand your search lookin in google for
por hdmi signal
Aug 29, 2015 | Televison & Video
Picture has red tint when macbook air is connected through HDMI
I have exactly the same problem with my mac mini when I connect it to my Sony Bravia with an HDMI cable which works fine with my Apple TV. Sorry I don't have an answer yet!
Nov 10, 2011 | Dell W3707C 37 in. LCD Television
I have a Gateway T-6330u and want to connect it to the TV to watch a movie, but I don't know how to do this. I searched the web and found I may need a HDMI cable, but I don't know if there are...
If your TV has a VGA input or the laptop and TV have HDMI run the cable over choose the correct input on the TV "pc or hdmi" my asus auto detects the hdmi stream you may have to right click on the desktop go into video setting and choose the TV.
Aug 22, 2011 | Gateway T-6330U Notebook
Both HDMI ports are bad due to lightening strikes. What do I need to do to fix this? Can you suggest part numbers?
The main tv Tuner signal board have problems and all those HDMI insert ports are shorted dead,those HDMI insert ports are put on by wave soldering machine and fused by iron core solders joints to the main tv Tuner board itself.These HDMI insert ports are not replaceable by hand soldering equipments or can buy those HDMI insert ports individually anyway.Tv still work wright?Yes? Why don't u just skips the used of those HDMI insert ports all together and tries used those RCA component cable connections like AV1 and AV2 on the tv.Or u must have some mechanicals skills and like take things aparts and putting back together again?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement to able to used those HDMI insert ports again.I have the same problems with my Samasung 46" all my HDMI insert ports are dead too,but the tv still functions.That what i did used RCA cable components connections for my cable box and blu Ray player.
Aug 03, 2011 | Sceptre X42BV 42 in. LCD TV
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
Hi, My screenplay director freezes after a few minutes of play, it can be either music,video or any file. The device cannot be shutdown and needs to be disconnected from the power outlet, i have tried...
I had the same problems for months....changed my chinese HDMI cable for a Phillips Gold HDMI and it never freezed or stopped anymore.also try the new firmware update from the official iomega site.
May 08, 2011 | Iomega ScreenPlay
Is the HDMI from the HD TV A/V go to the out HDMI?
No..... (In theory, yes.) In practical application, no. Run HDMI from your source directly to the TV then use digital coaxial or optical for audio to the receiver. There are many problems with HDMI while processing it thru a receiver. For all the info on HDMI problems, Google "HDMI problems" and there are literally 1000's of posts and articles to read regarding the current issues. Hope this helps
Nov 07, 2009 | Pioneer VSX-919AH-K A/V Receiver
Hdmi is connected, but invalid format is displayed on the TV
Check HDMI cable over version 1.3. If the HDMI cables you use don’t support HDMI version 1.3, it can cause flickers or no
screen display. In this case use the latest cables that support HDMI version 1.3.
Oct 25, 2009 | LG Televison & Video
Colours turns blue and green from HD channels
The most likely cause of your problem is the cable box HDMI output. If you have some extra cables, try connecting the TV to the cable box using the component connections. I'll bet your problem will go away. Don't let the cable company lie to you; I work on Sony TV's everyday and see plenty of cable box HDMI issues. Some of my customers have exchanged their boxes 4 or 5 times and still have HDMI issues. Your best bet is to use the component outputs or switch to Dish or Direct TV, as they DON"T have HDMI problems. If this solution works, be sure to rate it. Thanks!
Nov 11, 2008 | Sony KDF-E42A10 42 in. LCD Television
RCA P61960 61" Rear Projection Television Logo
141 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
