Question about HP Officejet 4110 All-In-One InkJet Printer
I add a new set of paper in the Infeed tray however the mechanism to accept the paper is NOT taking the feed, which always leads to "Out of Paper" error message...how to fix?
  • ronald_brewe Aug 30, 2010
    I changed the color ink toner cartridge, and the printer is trying to print a new Alignment page, but each time it goes to print the printer is NOT taking in the paper, and I get a OUt of Paper error message, when in fact the paper tray is full....what solutions do you have to fix this fault (no intake from a full paper tray)?? -Ronald
  • 857 Answers
Solution
Complete the following steps in the order provided to solve this problem.
Step one: Check the media and print settings
While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
If the printer is not already on, turn it on by pushing the power button.
Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.
NOTE: Use plain paper in the unit until the issue is resolved.
Verify that all the paper is the same size and type.
Tap the stack of paper on a flat surface to align the edges.
Verify that the stack of paper to be loaded in the unit contains between 10 and 25 sheets of paper.
NOTE: Do not load too much paper in the printer.
Insert the stack of paper into the printer and then gently push the paper guides snugly against the paper.
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
Open a document in the application in which it was created.
Click File .
Click Print .
Click Properties . The Printer Properties dialog box displays.
Click the Paper/Quality tab.
In the Size is drop-down menu, select the size of the paper loaded in the unit.
In the Type is drop-down menu, select the type of paper loaded in the unit.
Click OK .
NOTE: These changes do not change the default print settings. The print settings will revert to the default print settings the next time the application is opened.
On the Print dialog box, click OK to print the document.
Try printing again. If the issue is not solved, continue on to the next section.
NOTE: If the issue is resolved and you want to print on another type of media, change the paper in the unit and then repeat steps 2 through 7 for the new media.
Step two: Clean the rollers
Turn off the product and unplug the power cord.
Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
Close the access door and plug in the power cord.
Try printing again. If the issue is not resolved, continue to the next step.
Step three: Service the product
If you have completed all the steps and are still experiencing a problem, service your product.
Cause
Any of the following issues can cause this issue:
The paper trays are empty or overloaded.
The paper is curled.
The print side, or shiny side, of the paper is not loaded in the tray face down. For photo paper, always load the rougher side of the paper facing up.
The paper is too slick for the product.
The paper might not be engaged with the feed rollers.
The paper-width guide is pressed against the paper stack too tightly.
The paper tray is not completely inserted into the product.
The paper settings in the print driver do not match the paper loaded in the paper tray.
The rubber paper-feed rollers are dusty.
Posted on Aug 30, 2010
    Genius:
  • HP Master
  • 1,354 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Aug 28, 2010
Printer jam after first copy
  • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
  • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
If you need any technical help on printer then you can reach at here
Mar 08, 2013 | HP LaserJet 2300d Printer
Brother Printer HL 2142- has paper jam
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 06, 2012 | Brother Office Equipment & Supplies
I have a canon mp830 printer and the prompt says 'add paper'. there is plenty of paper. i have powered off several times and have changed and added paper, but it clicks and again says 'add paper' any...
hello, on the machines display/control panel there is a switch for paper feed, it might be set up for lower tray or back tray, depending on where you are feeding paper. also the computer usually overrides the printer, so might check to see if the paper setting on computer is set for the tray you are using.
Dec 27, 2010 | Office Equipment & Supplies
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
Xerox XC830, flashing 'P'
I have used this tip numerous times with great success.
Remove the paper tray and take all the paper out of the tray. Now on the metal plate that springs up where the paper goes there are 2 fiber pads that are about an inch square. Spray these 2 pads with glass cleaner until they are wet. Wipe off the metal around the pads and re-install the paper tray with NO paper in the tray. Now tray and make a copy....you will of course get the "P" light. Just hit C to clear it and hit the print button again. Do this at least 4 or 5 times. What you are doing here is cleaning the feed rollers by having them turn against the pads with the cleaner on them. Next take out the tray, blot the pads somewhat dry and add paper to the tray, re-install the tray and try copying again.
Should feed paper now unless you have a mechanical issue.
Good Luck.
Oct 29, 2009 | Office Equipment & Supplies
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
Paper won't feed
I know this sounds funny, but my Grandmother in law had the same problem, I turned the printer off, put a large amount of paper into the feed tray so the infeed rollers would pick it up, cut it back on the paper went thru and low and be hold out poped a lemon seed....
Hope this helps,
David
Nov 18, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
HP Officejet 4110 All-In-One InkJet Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
