Question about GE Refrigerators
Our GE Profile Refridgerator Model # Pfs22mbs/pfs22sbs freezes everything that you put into the humidity controlled drawers. This is a joke because I have no room in the fridge because I cannot put any produce in there without it freezing. I have wasted way too much food and am upset with it. Please help.
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 531 Answers
SOURCE: GE Profile produce drawer freezing the veggies
check the dooa and see if it (ajar)
Posted on Apr 01, 2009
woodchuck789
  • 4059 Answers
SOURCE: my refrigerator produce drawers are freezing all
Make sure the fan in the freezer is running to circulate the air through the fridge. The cold air will settle to the bottom if it's not. Make sure the vents from the freezer to the fridge are open. There's one at the top and bottom.
Make sure the dampers to the vents open and close when you adjust the temp.
Posted on Feb 10, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Cleaning the base of a GE Profile with a bottom freezer drawer.
Click Here=> PDS22MHR and go to page 11 in the PDF. I believe that will answer your questions of removal. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 19, 2010
  • 9 Answers
SOURCE: There is an ice build-up underneath the humidity
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Posted on Sep 24, 2010
No temperature display on my GE PRofile PFS22SBS!
Is it an electronic controller, or just a battery powered thermometer?
Aug 06, 2012 | Refrigerators
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Good Lucak!
Jan 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Nov 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
