Question about Port Incorporated Wireless 11Mbps (pun1000w) Print Server
Cannot configure the wireless USB Print Server
My father-in -law bought the Wireless USB Printer Server (http://www.connectgear.com/Print_Servers/PUN1000W.htm) last year but has not been able to install it since the day he purchased the product. I tried to install it yesterday but I failed as well. Below I will give you the details and symptoms of all my connection attempts: Router + Security Details WEP 64 enabled (I know... but the print server does not allow WPA) Windows + other firewalls disabled NAT selected on router Windows XP SP2 installed on PC The PC (Laptop) is wireless connected to the wireless network in the house. Scenario 1 The Print Server is switched on and connected to the HP printer which is also switched on. The print Server switch is set to "Normal" When running the wireless setup wizard(came with the print server on CD), it does not find the print server.(Step 6 in the on-line manual) When checking for wireless network in Windows, the print server is NOT listed. Scenario 2 The Print Server is switched on and connected to the HP printer which is also switched on. The print Server switch is set to "Diagnostic" When running the wireless setup wizard(came with the print server on CD), it does not find the print server.(Step 6 in the on-line manual-see attached) When checking for wireless network in Windows, the print server IS listed as an PC-to-PC connection. When connecting to it (I lose my connection to my wireless router) it allows me to connect.
While connected to the Print Server's PC-to-PC connection I run the Wizzard again.
I can now see the print server as described in step 6 of the on-line guide (see attached)
I change the setting to allow the print server to connect to my wireless router (Optain IP automatically, SSID, comm type , WEP encryption 64-bit + key...... )
Installation Complete!! Then I run the Network Print Server Setup Wizzard to setup the printer on the network. (I am still on the PC-to-PC connection, directly connected to the print server. I am not on my wireless home LAN) It does find the Print Server as before and it does list my printers. When I try to install the printer, it gives me an error because the IP address in the PC is not part of the LAN wireless NW (but the IP address set on the print server does). When I connect my laptop to mw wireless LAN and run the Network Print Server Setup Wizzard again, I cannot find the print server when scanning for it. That is more or less what is happening. Any ideas on how to get it set up correctly?
  • 115 Answers
First delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
Posted on May 12, 2009
How to make a printer wireless
Plug into a wireless print server.If your printer has a USB port, you can plug in a wireless print server, a small box into which you can connect your printer. The advantage of investing in a print server is that you don't have to connect the printer to a PC, which means you can use your laptop and print anywhere in your home.
.tmnAdsenseContainer{margin-bottom:10px;} We found plenty of print servers in the $50 range on Newegg.com, although many of the models cost closer to $75 or $100). Before you buy, make sure the print server is compatible with your printer (the printer's written materials are less likely to specify compatibility with print servers).
During the setup, you will have to plug the printer into the printer server, and connect that to the router using an Ethernet cable. Meanwhile, you'll have to install software on your computer and configure the connection, as you would when setting up a router.
also try this link will help you
http://www.makeuseof.com/tag/printer-wireless/http://www.ehow.com/how_4530941_make-printer-wireless.html
http://www.labnol.org/gadgets/make-wired-printer-wireless/12639/
Dec 27, 2012 | Samsung Office Equipment & Supplies
Wirelessly connect to hp deskjet f380 printer
This model printer only has USB printer connection and it cannot be connected to a wireless network directly.
If you have a wireless router then you can connect a print server to this HP printer and then connect the print server to the wireless router. This will allow you to print wirelessly yo the HP printer when you configure the printer server and configure the printer driver in the computers to connect to the printer port IP address of the print server.
Jan 26, 2012 | IBM Computers & Internet
Please give instruction of how to print wireless from my laptop to the Brother DCP 7030 printer.
Hi 123sweetdrea
WIRELESS PRINTING WITH WIRED BROTHER DCP 7030 PRINTER
Your printer is not a wireless printer so you need some additional equipment to create a wireless printer setup.
If your computer is a laptop, its wireless function would work seamlessly in a wireless printer environment. If your computer is a Desktop computer, all that would have been required would be (if you don't already have one) an inexpensive Wireless USB Adapter to plug into the back of the Desktop to transform your setup into a fully Wireless Network. You need a USB Wireless Print Server to link your wired printer to you wireless router/modem. Click here for an example:
http://www.amazon.com/s/ref=nb_sb_ss_c_1_25?url=search-alias%3Delectronics&field-keywords=usb+wireless+print+server&sprefix=usb+wireless+print+server#/ref=nb_sb_ss_i_2_18?url=search-alias%3Delectronics&field-keywords=usb+wireless+printer+server&sprefix=usb+wireless+print&rh=n%3A172282%2Ck%3Ausb+wireless+printer+server
Also here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=usb+wireless+print+server&x=0&y=0#/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=usb+wireless+adapter&rh=i%3Aaps%2Ck%3Ausb+wireless+adapter
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 25, 2011 | Computers & Internet
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Instructions
· USB printer
· Ethernet cable
· Computer
1. Step 1
Step 7
Step 10
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Can you connect it to your computer by wireless
Sure can. Just buy a wireless print server with USB output. They are made by most big names like: Trendnet, D-Link, Linksys, Netgear, etc. I see them on Ebay for low prices 5-20 dollars.
Just make sure you get a match to the router you have for frequencies. For example: G or N
Good Luck
Jan 03, 2010 | Samsung CLP 300 Laser Printer
WHAT KIND OF WIRES DO WE NEED TO HOKUP A LEXMARK X3350 ALL IN ONE PRINTER.
Standard Ports USB Compatible with USB 2.0 Specification (Type B)
Optional Network Ports Lexmark N4000e Fast Ethernet (Print Only)
Lexmark N4050e 802.11g Wireless Print Server (Print Only)
According to:
http://www.lexmark.com/lexmark/product/home/277/0,6970,204816596_653399443_473191701_en,00.html?tabId=1
Sep 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
Connecting laptopto printer wirelessly
You'll need the "wireless print server" that plugs into your computers USB port, and that unit must be "configured"(by using the software it comes with.) Then you can turn on and use your printer....Goto lexmark.com for info.
Dec 05, 2007 | Lexmark X4270 All-In-One InkJet Printer
WANT TO CONFIGURE IT
First make sure the PS is hard wired to the router and you have all the wireless settings handy (including the SSID and Wireless Encryption). Then follow the step by step instructions in the file given below: ftp://downloads.netgear.com/files/netgear1/ps104105110inst_eng.pdf Also, the printer with the ethernet cable seems to be a network printer. So, you need to do much to configure it, if its already configured; just connect it to one of the ethernet ports of the PS. Please revert back with any other queries.
Mar 14, 2007 | NetGear PS111W Print Server
Port Incorporated Wireless 11Mbps (pun1000w) Print Server Logo
633 people viewed this question
Top Port Incorporated Computers & Internet Experts
David Payne
David Payne
Are you a Port Incorporated Computer and Internet Expert? Answer questions, earn points and help others
