Question about Samsung DualView TL220 Digital Camera
My camera wont turn on. even when i plug it into the charger. when i plug it in the triangle flashes red,green, then orange but wont charge the camera. whats wrong with my camera?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
My charger flashes red/green and does not charge my scooter. Any suggestions?
hi the red led should not flash the green led should only come on when batteries r charged while charging the green led turns orange or yellow....can u borrow another charger just to check to c if its not the scooters charging circuit that is the problem..or the batteries ..good luck
Sep 19, 2015 | Health & Beauty
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
No battery light on charger on samsung st500
The rechargeable battery sounds like the main problem, but the charger needs to be checked to make sure there is not a secondary problem.
Jul 04, 2012 | Cameras
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Jun 25, 2009 | Samsung L100 Digital Camera
When i plug in my usb charger, the light flashes red green then orange. even without my battrie
try cleaning the battery(copper bits) try charging it on your lap top, it should flash red green orange, keep unplugging and plug back in again its worked for us
Jun 24, 2009 | Samsung NV3 Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Samsung DualView TL220 Digital Camera Logo
87 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
