Question about Whirlpool Washing Machines
WHIRLPOOL WASHING MACHINE WFS1072AW START BUTTON IS STUCK IN
SOURCE: whirlpool washing machine will not start indicator
opened bottom panel of washing machine unscrewed filter drained out water found cloth item in pump area cleaned out ok for a while problem reoccured repeated process more cloth found problem resolved.
Posted on Sep 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: start button not working on whirlpool cabrio
It sounds like your thermal fuse is out. You can check it for continuity with an ohm meter, make sure your dryer is unplugged first! Or you can take the wires off the thermal fuse and use electrical tape to tape them together to see if it will come on.
CLICK HERE for the TECH SHEET on your washer... and HERE to see the thermal fuse.
Sometimes the plastic start button can break a little tab off the back as well, so check it as well.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2009
barkencoa
  • 3463 Answers
SOURCE: The top off Hotpoint WMA35 washing machine?
Located at the front end of the top cover, are 2 plastic covers, prise them out with a small screw driver or something similar, and inside are 2 torx screws, get a torx screwdriver, and undo the 2 screws, if tyou don't have the correct screwdriver, you may be able to undo them with a small screwdriver.
Give the top a good hard push towards the rear, and it should come off..
Hope this helps.
Posted on Dec 28, 2009
  • 343 Answers
SOURCE: i have a whirlpool awo 3751 washing machine when i...
You most probably have a faulty water inlet valve...Not an uncommon problem..They can sound ok, but when you check the detergent drawer there will only be a trickle..Replace the inlet valve...Good luck...Nomess
Posted on May 24, 2010
gregory_91
SOURCE: front loading whirlpool machine WFS1072AW which needs pump clean
WFS1072AW has a clip in panel at the bottom across the front.
Removing this will reveal a black plug on the right.
Unscrew this and water will gush out along with (hopefully) the offending coins.
Posted on Sep 06, 2010
Broken dial/selection knob on whirlpool wfs1072aw-7.5
The knob should pull straight off or it should unscrew counter clockwise. What is the model number of the machine?
Mar 19, 2014 | Whirlpool Washing Machines
I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
May 08, 2012 | Whirlpool Washing Machines
Changing pump on whirlpool washing machine WFS1072AW. I need a new pump (so I've been told as the single part isn't available for sale) as I've broken the black screw/cap that seals the pump. I...
take your new pump back and look in the paper for someone who sells used washers and call to see if they have the part u need,they getthe washers for free to remove may have what u need
Sep 17, 2011 | Whirlpool Washing Machines
Front loading whirlpool machine WFS1072AW which needs pump clean
Feb 13, 2010 | Whirlpool Washing Machines
Washer machine stuck in middle of washing cycle, how to reset and restart wahcing cycle
Disconnect the machine from the power outlet. Wait for some time. Reconnect it and push the start button. It will start the wash cycle afresh.
Jan 17, 2010 | Whirlpool WTW5700S
I have a whirlpool WFS1072AW washing machine. a red light comes on to clean pump. I am not sure how to do it
The WFS1072AW has a clip in panel at the bottom across the front.
Jan 07, 2010 | Whirlpool Washing Machines
Lost the Booklet - Need to Print new one.
I am seventy five and I do not want to join a site with a silly name like FixYa. All you have done so far is to send me on a wild circular search for a very simple request. I want the site where I can download the operating instructions for the above washing machine. That is not asking too much surely?
Jill Briggs
Nov 24, 2009 | Washing Machines
Washing Machines Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
