Question about Proview PL926WBi 19" LCD Monitor
Sence yesterday morning when i turn on my Proview PL926WBi 19" LCD the power light flash's for a while with a black screen then come's on and work's fine. what is wrong with it??
  • 11,361 Answers
It may have dying power supply due to bad DC filter caps, it will more likely to get worst and more components inside will be damaged.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Capacitors kit: <a rel='nofollow' href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a> he can make you a set of caps for you.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a rel='nofollow' href="http://www.badcaps.net/">http://www.badcaps.net</a></span>
Posted on Aug 27, 2010
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
My monitor was fine last night, when i woke up this morning it would not come on, the blue light is flashing, help
Press and hold the button, until the monitor turns itself off.
Then, turn it on, and hope that it works correctly.
Aug 21, 2010 | Proview PL926WBi 19" LCD Monitor
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19# model PL926Wbi
thers Sounds like the problem I'm having /had exactly. When I opened the case I found that like others the 470mf capacitors on the power board had gone bad. (See the post from Delphiuser)
The capacitors are probably from a Chinese company called Xandu and I'm currently looking for a replacement capacitor to fit the circuit. Its a 470 mf cap with a 25 volt rating .
May 01, 2008 | Proview PL926WBi 19" LCD Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
62 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
