Question about Tanita Health & Beauty
Jenny Craig Tanita Scale BF-592J keeps showing error code & I don't have the manual . I need help to set to work properly.
SOURCE: How do I set Tanita digital scale with 2 memory
Go to www.Tanista.com/ProductManual/PDFs/2001_manual.pdf
This should provide the answers you are looking for.
law4644
Posted on Jan 21, 2009
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
SOURCE: need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Posted on Jan 20, 2010
SOURCE: does having water effect the
Yes. These systems work by what could be broken down as, "Bio-electrical Impedance Monitoring".
Meaning, they measure the amount of resistance in your body to determine the "volume %" of non-resistive materials (fat and water). Since bones and muscle are very dense in comparison, the scale can calculate the total weight of a person, then determine their "expected BF%). Fat is about 80-90% water depending on your genetic makeup, and it would only make sense that if you where full of fluids (either by ingesting large amounts or by fluid build up under the skin) that your BF% would read higher. My professional suggestion? Use it only after waking and before any morning drink or food.
(REMEMBER...THESE THINGS WILL NEVER BE EXACT!!!) Hydrostatic weighing in the only way to be 99%+ on your BFC (body fat composition)
GOOD LUCK AND PLEASE RATE THIS POST!!
P.S. one way to test this method is to hold something heavy in your hands and watch it consider that weight Lean Muscle Tissue. Then stick your hands in a sink full of still water (moving water posses a small electrical charge that could give a false reading) and watch your BF% increase.
Posted on May 09, 2011
SOURCE: CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Posted on Oct 23, 2011
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.
1. Press&Hold Zero button, then Press&Hold On/Off.
2. Release.
3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.
4. Press Set button to select mode.
Hope this helps!
Mar 23, 2012 | Tanita BF 350 Pro Body Composition...
Someone has switched my tanita BF 625 to metric readout and i don't know how to switch it back
Press the set and arrow UP button at the same time. Then use arrow UP to find lbs. Press the set button to confirm.
Jan 29, 2011 | Tanita Digital Body Fat Scale with 2...
Need to reset scale bf-681 tanita scale
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Error reading 5
be sure you are barefooted when weighing yourself
Oct 05, 2009 | Tanita BF-350A - Body Composition...
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Need manual for Tanita scale 520806M1. I need to know how to set this scale; please help.
Tanita Corporation of America, Inc.
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005, USA
Phone: (847) 640-9241
Fax: (847) 640-7978
eMail: 4health@tanita.com
Jul 30, 2009 | Health & Beauty
Jacob
Apr 08, 2009 | Health & Beauty
When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Health & Beauty Logo
448 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
