Question about Maytag Neptune MDE5500AY Electric Dryer
The inside of my dryer has three part that stick out to the inside about 4 inches that help to toss the clothes around to keep them fluffy. One of these parts is lose and making the clothes make a loud noise when they are tumbled. Can this part be replaced and what is the part called
  • looneyrus Aug 26, 2010
    so where do I get one from??
  • looneyrus Aug 27, 2010
    How hard is it for someone that knows nothing to mount the baffle. I can read directions but does the whole tub have to come out to mount the baffle??
  • 15,935 Answers
This is an agitator - and yes it can be replaced. Chances are good it might just be loose.
Thanks!!
Posted on Aug 26, 2010
  • 1 more comment
  • blueextc3221
    blueextc3221 Aug 26, 2010
    head over to www.repairclinic.com and enter your full model # and a parts list will pop up.
    does the baffle just snap it or do I need to buy a repair kit
  • blueextc3221
    blueextc3221 Aug 27, 2010
    no it is not just a snap fitment. There are parts to disassemble. The middle cap of the nunator does snap off to reveal the mounting bolt.
    Instructions for replacement will be included with the replacement part - or you can re-post here if you have troubles.
    THanks!
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
How to change a dryer door switch for kenmore part number 8574875?
for a dryer door that is broken, if you need to use it before you can fix the connection to close it ...get a heavy duty stick on Velcro and cut about three inches or four if the room allows make sure you have it places where it closes together one on one side then the part that closes together tight on the door inside push hard so it is stuck to both parts of the dryer door and push hard it keeps it shut so the dryer can dry your clothes just the same as if it were latched with metal or magnet attachments ..my kenmore was troubleshot this was for years
Sep 08, 2014 | Kenmore Dryers
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
The cooling light is always on and the clothes take forever to dry!
Inside the dryer, near the lint filter, you will find two curved metal bars, about 1/4 inch wide each, about an inch apart and about 4 inches long. These sense the moisture in the clothes. When fabric softener sheets are used, a waxy substance will eventually coat the bars, so the dryer will not "see" that the clothes are still wet, and go right to a cool down. Clean them off, or use time dry only.
Jan 17, 2011 | LG DLE2512W Electric Dryer
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Dryers
Clothes sometimes get under the agitator requiring the removal of agitator to release. Also, clothes get wrapped around agitator
Sounds like your agitator is not assembled correctly. It should not have things getting stuck constantly and it should definitely NOT be so easy to remove. Feel around the bottom edge of your agitator. If there is more than a 1/8 - 1/4 inch gap (roughly), it's not being snapped all the way down. Take a towel and fold it to where it is nice and fluffy. Lay it over the top of the cone part of your agitator. Get a hammer and hammer over the towel (as not to damage the agitator top). A rubber mallet could also be used. Tap firmly until you hear a click or until the gap between the agitator and wash tub reach 1/4 -1/8 of an inch. This should solve the problem.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Whirlpool Washing Machines
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
My daughter left clothes in the dryer and they werent dry now my dryer smells soured. how do i get rid of the smell?
Try tossing a tad of dry baking soda in with the clothes in may take a time or two but it would be better than tossing the dryer. If it smells like mildew also maybe try placing some charcoal inside withe door shut, charcoal draws mildew.
Nov 06, 2009 | Estate TEDX640JQ Electric Dryer
Electric clothes dryer will not turn on
Check in the upper corner of the dryer when you open it. There should be a slot where a little tab sticks out. This is the door switch. The tab should stick out about 3/4 of an inch. Is it broken? Dave www.washermd.com
Dec 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
My Admiral AU40001 keep giving fluffy stuffs
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Uh Oh, better call factory service before you have real problems!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Aug 21, 2008 | Admiral AW22 Top Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
13 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
