Question about Philips GOGEAR SA6045 MP3 Player
It won't turn on
Hello Mp3 Doctor! My go gear won't turn on after being accidentally dropped last week. However, when I plug it in with a usb cable, it turns on and I can use it, but its not much good when I need to leave the house. I saw your reply to someone about holding the volume + button etc, but when I did that, it asked for the installation cd to be put in, and I have no idea where that could be. Are there any other solutions you could give me for this?
  • Laurabubbles May 06, 2008
    p.s I tried it again, and it automatically installed for me, however, the mp3 still won't turn on for me.
  • 8,596 Answers
Software that was on install cd can be downloaded from:
www.usasupport.philips.com
enter in your exact model number and then click on the software and drviers link
Posted on May 16, 2008
Ok, i went to plug in my headphones, and the mp3, froze so i hit the reset button like i always do when it freezes, but this time it wouldnt turn back on, and the computer stopped reading it, so i dont no wat to do.
Posted on May 08, 2008
Hello i would like to know where i could get a charger for my MP3 players as im going abroad in 2 weeks
The MP3 player is charged using the USB cable and connecting it to a computer.
The other way of charging a MP3 player is to get a mains adapter with a USB socket. These chargers produce 5 volts and you just plug the USB cable from the MP3 player into the adapter.
These adapters are available at a computer or electronics shop or on the Internet.
Sep 09, 2010 | Audio Players & Recorders
My Phillips Go Gear player wont work
Make sure the hold/lock switch wasn't accidentally activated.
If it is freezing, update the firmware.
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
-Tha Mp3 Doctor
Mar 27, 2009 | Philips Audio Players & Recorders
I drop my E100 mp3 in a water accidentally.
Let it sit and dry for a week without trying to turn it on or charge. After that, plug it in to charge and then try to turn it on. It may still function, but there are no guarantees. Water is the quickest way to kill any electronic.
Mar 25, 2009 | iRiver E100 Digital Media Player
System erro
The "File System Error" message is bad - it means that, rather than deleting just music files, you have accidentally deleted a key system file required for the Go Gear to operate properly. If you are still under warranty, call Philips and get a replacement GoGear, because they do not provide replacement files.
-Tha Mp3 Doctor
Feb 16, 2009 | Philips Sport Personal CD/MP3 Player
Sandisk sansa clip mp3 only comes on when plugged into a usb con.
Try holding in the power button for about 5-7 seconds, and then release. Also, make sure the hold/lock switch was not accidentally engaged.
-Tha Mp3 Doctor
Feb 13, 2009 | SanDisk Sansa Clip MP3 Player
I try to download songs, but AutoPlay keeps popping up.
Test another USB port on your computer, and see if you get the same result. If you get the same result, the USB cable may be faulty.
Here is a test you can do to see if the problem really is the USB cable, or if it is something else:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 02, 2009 | Philips SA3025/37 Flash MP3 Player
My USB cable can't be read
Upgrade the firmware by downloading the latest version of the Philips Device Manager from www.usasupport.philips.com and clicking on the Update tab.
-Tha Mp3 Doctor
Jan 21, 2009 | Philips SA3025/37 Flash MP3 Player
I dropped my MP3 player in a puddle of water. I
Even drying doesn't usually help. Water kills electronics - period. That is the only solution I can offer, because that is the only correct answer.
-Tha Mp3 Doctor
Dec 18, 2008 | RCA OPAL M4001 MP3 Player
How to take music from go gear to your harddrive
Connect the Go Gear to the computer
Double-click on My Computer
Double-click the icon of the Philips
Double-click the Music folder
Create a new temporary fodler on your desktop or some other location on your computer.
Start dragging and dropping from the Philips music fodler to the new temporary folder.
--Tha Mp3 Doctor
Dec 12, 2008 | Philips GoGear HDD075/17 MP3 Player
I turn on my Go Gear and it freezes
Get a firmware upgrade...whenver you reset the device it reset the firmware install..so get the firmware upgrade and that should solve the problem you are having..hope this solve the problem
Jan 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
21 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
