Question about Savin 9935DP Laser Printer
Savin 8020d is not printing how can i fix it
  • 2,973 Answers
Please un and reinstall following the link below:
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Aug 26, 2010
Black will not print on a savin clp22
Please make sure that the toner tape is pulled from the cartridge or try a new black toner cartridge.
Oct 16, 2013 | Savin GENUINE RICOH FUSER UNIT (402451)...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
I purchased a Savin 9021d about 3 weeks ago. Whenever I place an original on the glass, the left side of the print is black. Could you help me with this problem?
Hi Joy,
This is indeed an odd problem.I have been factory trained on this device and have been servicing SAVIN, Canon, Kodak and Toshiba copiers for going on 23 years. If you were not covered by the warranty included in your new purchase I might hazard a guess. But that is a unexplainable problem and I would be asking you to perform checks and tests that truly you need not do. Contact the dealer you purchased this device from as you have a 90 day warranty and let them make it right. It's not that I would not to help. It's just such an exotic problem that I believe it would not be good for us to "mess" with things (like changing service mode settings or anything that might void your warranty) since Savin( made by RICOH) MUST take care of this problem. Go to SAVIN.com and go to support and find a dealer in your area. They will come in at no charge and fix the problem. Believe me, SAVIN devices are as good as any. You merely need to have them , or their authorized dealers in the area fix your problem.If they can't or won't (which is absolutely incorrect) then please re-submit your question. But please understand that that whomever you bought the copier from is required by law to maintain it and service it for the first 90 days. Just for you knowledge it sounds like one of the *(I believe 4 mirrirors) are out of adjustment. This could happen if you moved the copier in a rather rough way. If this is the case don't say anything. Again you have a warranty and unless they can prove you did something ( that's not what I'm saying) then just say you want the problem fixed. Sounds to me like your "****" is covered.If you need further help then please shout out. If this is a used copier and was not purchased new then, again, shout out. I can help you isolate the problem. You take care ! :-) Spinal
Mar 08, 2011 | Savin Office Equipment & Supplies
I have a savin c4040 and when we want to copy a sheet 8 1/2" by 11" it automaticlly prints on a 11" by 17" how do i fix that?
try to ensure that paper standard in copier has congruent with your computer for more detailes call us
Dec 30, 2010 | Savin 2545DP Black and White Copier
I have a Savin 9400 copy machine. It will not print 2 sided copies. Everytime I try to print a 2 sided copy, it jams after it prints the first side and before it prints the second side.
Hello sir; You need to clean the reverse roller with alcohal, if you don't know which one is reverse roller then you can clean up all the roller in duplex unit.
Aug 28, 2009 | Savin Office Equipment & Supplies
Savin 2513F, prints PDF files intermittently
I'd try a different driver, if your using RPCS, change to PCL5. You may have to upgrade the firmware in the copier too.
Aug 26, 2009 | Office Equipment & Supplies
133 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
