Question about Panasonic Cameras
Hi when i turn my camera on it makes a sound like the lens is trying to retract to the face of the camera.Then on the display it says please switch camera on and off i have done this several times to no avail.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
Lens will not retract and camera turns itself off
It could be that there's a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely.
So here is what you do. Make sure your battery is fully charged. With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. If the above solution does not work, you might need to blow a canned air around the sides of the lens of your camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Apr 25, 2011 | Cameras
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
When switching my camera on it just switches itself straight back off?
Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
Nov 06, 2010 | Kodak Easyshare V1233 12.1MP Digital...
When power ON the screen displays"Lens Error!" & lens does not open.
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 04, 2010 | Nikon Coolpix L1 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens wont retract
When the lens will not retract and camera is not functional (no picture ondisplay, and does not shoot) , and you already tried replacingbatteries with a new fresh set (ensure please) , and then restartingcamera with no memory card inside, then camera is faulty.
Try aneasy fix by pushing gently the lens (do not force them, just help them)while you turn off camera at same time. Try also switching the modeselector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair frommanufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Feb 18, 2009 | Sony Cyber-Shot DSC-S85 Digital Camera
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Aug 03, 2008 | Fuji FinePix F20 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Cameras Logo
12 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
