Question about Xantrex Technology Heart Freedom 20 12 Inverter
I need to order a circuit board for my Heart Freedom Combi 2000 watt inverter. The part # is 70013103. I can install it my self. My board has a stuck relay. Who can I order this from? Terry
3 Suggested Answers
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Posted on Sep 08, 2009
kel1guy2002
  • 3740 Answers
SOURCE: my 2000 Fleetwood Discovery Motorhome
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
Xantrex freedom 2000 watt inverter/ charger
Hi
Your x anter freedom inverter can't run all those items it is being over worked ( overloading ) that's why it is heating up and if not carefull wit will explode .
May 07, 2017 | Xantrex Electronics - Others
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
I need a replacement comm board for a Xantrex Freedom Marine 25-12 Inverter/Charger. The battery temp sensor got shorted out and probably caused damage to the installed comm board.
I have the same unit that the charging function just died on. If I can't fix it and have to buy a new one, you can have my comm board for free. Should know my status in ~ a week .
Jul 03, 2010 | Xantrex Technology Heart Freedom 30...
Freedom 20 stopped working after ac breaker tripped
How do you get the PCB out all the 4 screws are out and clips are pushed off the pcb contacts on the sides. Unscrewed the antenna, but not the soldered in bulk antenna mount. I is still locked in somehow? how do I get the board out to look at the keypad buttons so I can see if threre is a bad contact?
Sep 10, 2009 | Xantrex Technology Heart Freedom 20 12...
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
225 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
